Remote starter Installation for FORD 2002
Home /
the12volt's Install Bay /
Car Security and Convenience / Remote starter Installation for FORD 2002 (
Topic Closed)
Welcome Guest :)
Posted: November 15, 2002 at 10:36 PM / IP Logged
{p}In better format...{/p}{p}I downloaded the wiring info for the Ford Explorer 2002 from this great site {a class="fPost" href="https://www.the12volt.com/installbay/display_topic_threads.asp?ForumID=1&TopicID=3278" target="_blank"}https://www.the12volt.com/installbay/display_topic_threads.asp?ForumID=1&TopicID=3278{/A} and the module wiring diagram for the Impulse RES {a class="fPost" href="https://www.the12volt.com/downloads/file.asp?ID=278" target="_blank"}https://www.the12volt.com/downloads/file.asp?ID=278{/A}{/p}{p}Now I beg for help to put the wires together...{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /}{face="Arial" target="_blank"} {/SPAN}{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{B style="mso-bidi-font-weight: normal" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}MODULE{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}CONNECT TO:{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}FORD EXPLORER {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{B style="mso-bidi-font-weight: normal" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}RED...........................CONNECT TO SRTONG SOURCE..................................................12v / YELLOW ??{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}YELLOW{SPAN style="mso-tab-count: 1" target="_blank"}.....................................{/SPAN}CONNECT TO TRUE IGNITION. {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{face="Arial" target="_blank"}{B style="mso-bidi-font-weight: normal" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}THIS IS THE SYSTEM IGNITION OUTPUT{/SPAN}{SPAN style="FONT-SIZE: 10pt" target="_blank"} ASSURE THAT {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}THIS WIRE REMAINS ON DURING CRANKING{SPAN style="mso-tab-count: 1" target="_blank"}..............................IGNITION{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}RED / LT.GREEN ???{/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}YELLOW / RED.....ACCESSORIES OUTPUT. THIS IS THE OUTPUT{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}WHICH WILL POWER THE HEATER AND AIR CONDITIONER {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}SYSTEM DURING REMOTE START{SPAN style="mso-tab-count: 1" target="_blank"}...........................................{/SPAN}ACCESSORY GREEN/ LT GREEN???{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{/SPAN} {/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}PINK{SPAN style="mso-tab-count: 1" target="_blank"}.........................{/SPAN}+ START INITATE INPUT{SPAN style="mso-tab-count: 1" target="_blank"} ...............................................................{/SPAN}STARTER RED ???{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{/SPAN}{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}ORANGE / WHITE{SPAN style="mso-tab-count: 1" target="_blank"}..........{/SPAN}CRANK OUTPUT THIS IS THE OUTPUT {SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} THAT CRANKS THE STARTER DURING THE REMOTE START{/SPAN}{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}ALSO USED FOR STARTER BYPASS{SPAN style="mso-tab-count: 1" target="_blank"} ...........................................................................{/SPAN}{SPAN style="mso-spacerun: yes" target="_blank"}?????????????????{/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}BLACK ON 14 PIN HEADER ....{/SPAN}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}CONNECT TO LOW IMPENDANCE{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}GROUNG A CLEAN CONNECTION IS{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}A MUST {SPAN style="mso-tab-count: 1" target="_blank"}........{/SPAN}I GUESS TO THE {SPAN style="FONT-SIZE: 10pt" target="_blank"}BATTERY {SPAN style="FONT-SIZE: 10pt" target="_blank"}{/SPAN}{SPAN style="FONT-SIZE: 10pt" target="_blank"} GROUND???{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{/SPAN}{/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}WHITE / GREEN............{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}ALARMS SHOCK SENSOR BYPASS {B style="mso-bidi-font-weight: normal" target="_blank"}{I style="mso-bidi-font-style: normal" target="_blank"}{U}INPUT {/U}{/I}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}CONNECT TO ALARM SHOCK SENSOR OUTPUT{SPAN style="mso-tab-count: 1" target="_blank"} .................................................... {/SPAN}??? IN WHAT???{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{SPAN style="mso-tab-count: 2" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}WHITE{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}/ RED..............ALARMS SHOCK SENSOR BYPASS {B style="mso-bidi-font-weight: normal" target="_blank"}{I style="mso-bidi-font-style: normal" target="_blank"}{U}OUTPUT{/U}{/I}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}CONNECT TO ALARM SHOCK SENSOR INPUT{SPAN style="mso-tab-count: 1" target="_blank"}...........................................................{/SPAN}??? ALARM ???{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{SPAN style="mso-tab-count: 2" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}ORANGE....................INGNITION BYPASS OUTPUT. CONNECT TO{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}IGNITION INPUT OR AFTER MARKET ALARM. {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}THIS WIRE FOLLOWS THE IGNITION OF THE CAR, {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}EXCEPT WHEN SYSTEM IS IN START MODE{SPAN style="mso-tab-count: 1" target="_blank"} .....................................................................{/SPAN}???HUMM???{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{SPAN style="mso-tab-count: 2" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}YELLOW / BLACK ................{B style="mso-bidi-font-weight: normal" target="_blank"}{I style="mso-bidi-font-style: normal" target="_blank"}NEW 15 AMP 2{SUP}ND{/SUP} IGNITION OUTPUT {/I}{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}15A 2{SUP}ND{/SUP} IGNITION OUTPUT{SPAN style="mso-tab-count: 1" target="_blank"} ..............................................................................................................{/SPAN}??? WHAT{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}???{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}GREEN................................(-) DOOR CONNECTION{SPAN style="mso-tab-count: 1" target="_blank"}................................................................ {/SPAN}GROUND ???{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}PURPLE.............................(+) DOOR INPUT{SPAN style="mso-tab-count: 1" target="_blank"}...........................{/SPAN}DOOR TRIGGER{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}BLACK / LT BLUE ???{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}DRIVER KICK PANEL{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}BLUE {SPAN style="mso-tab-count: 1" target="_blank"}.................................. {/SPAN}(-) START INITIATE INPUT{SPAN style="mso-tab-count: 1" target="_blank"}.......................................{/SPAN}??? ANOTHER ONE???{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{SPAN style="mso-tab-count: 2" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{/SPAN}{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} PINK / BLACK...................BREAK PEDAL(+) INPUT. {/SPAN}{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} DISCONTINUES REMOTE START WHEN PRESSED{SPAN style="mso-tab-count: 1" target="_blank"}................................{/SPAN}BRAKE WIRE TAN /RED {/SPAN}{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} TO LT.GREEN/ BRAKE PEDAL SWITCH{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}WHITE / BLACK{SPAN style="mso-tab-count: 1" target="_blank"}................{/SPAN}OPTIONAL (-) COIL TACH INPUT.{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}DO NOT CONNECT UNLESS THE REMOTE {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}START FAILS TO RETRY IF THE FIRST CRANK ATTEMPT FAILS.{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}CONNECTS TO THE (-) OF THE Coil {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}KEEP AWAY FROM HIGH VOLTAGE WIRES IF USED{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 2.5in; TEXT-INDENT: -2.3in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}SET WITH {B style="mso-bidi-font-weight: normal" target="_blank"}SW5 TO OFF{SPAN style="mso-tab-count: 1" target="_blank"}.........................................................................{/SPAN}I THINK THE{/SPAN}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} TACHOMETER {/SPAN}{/SPAN}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}IGNITION COIL/PACK DO NOT {/SPAN}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}USE WHITE / LT.BLUE{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 2.5in; TEXT-INDENT: -2.3in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{/SPAN} {/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} PURPLUE / WHITE..........THIS IS A MULTI FUNCTION {/SPAN}{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} OUTPUT: {B style="mso-bidi-font-weight: normal" target="_blank"}IF SW3 = ON THIS IS A SECONDARY (-) {/SPAN}{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} CRANK OUTPUT. {/SPAN}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}CAN BE USED FOR PATS OR OTHER BYPASS FUNCTIONS{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{face="Arial" target="_blank"}{B style="mso-bidi-font-weight: normal" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"} IF SW3 = OFF {/SPAN}{SPAN style="FONT-SIZE: 10pt" target="_blank"}THIS OUTPUT ACTS AS A FACTORY{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}REARM OUTPUT (THE OUTPUT WILL PULSE ONE TIME AFTER{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-spacerun: yes" target="_blank"} {/SPAN}THE CAR HAS STARTED VIA REMOTE){SPAN style="mso-tab-count: 1" target="_blank"}{STRONG} .........................................................{/STRONG}IN ENGLISH {SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}PLEASE???{/SPAN}{/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-tab-count: 1" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-tab-count: 2" target="_blank"} {/SPAN}{/SPAN}{/SPAN}{/SPAN}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-tab-count: 2" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}BROWN..................ACTIVE (-) USED FOR BYPASSING{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} FACTORY ALARMS............................................................................................................ {/SPAN}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}??WHATEVER{SPAN style="mso-tab-count: 1" target="_blank"} ??{/SPAN} {SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}{SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}{/SPAN}{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} WHITE................................PARKING LIGHTS OUTPUT {/SPAN}{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}(12V+ 15Aa UP TO 50A INRUSH) CONNECT TO ONE {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 3in; TEXT-INDENT: -3in" target="_blank"}{face="Arial" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}OF THE PARKING LIGHTS OF THE CAR{SPAN style="mso-tab-count: 1" target="_blank"}.......................................................{/SPAN}PARKING LIGHTS + BROWN {SPAN style="mso-tab-count: 1" target="_blank"} {/SPAN}HEADLIGHT {/SPAN}{st1:place}{SPAN style="FONT-SIZE: 10pt" target="_blank"}SW OR{/SPAN}{/st1:place}{SPAN style="FONT-SIZE: 10pt" target="_blank"} DRIVERS {/SPAN}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}KICK.{/SPAN}{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} {/SPAN}{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} {/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} Please Help me to fill the blanks....{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}Thanks{/SPAN}{/p}{P class=MsoNormal style="MARGIN: 0in 0in 0pt 0.2in; tab-stops: .95in 221.4pt 293.4pt" target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"}JR{/SPAN}{/p}{P class=Mso target="_blank"}{SPAN style="FONT-SIZE: 10pt" target="_blank"}{face="Arial" target="_blank"} {/SPAN}{/p}Please do not copy and paste from a rich text editor like Microsoft Word. Please copy and paste from a plain text editor like Notepad.
Posted: November 15, 2002 at 10:41 PM / IP Logged
??????????/Jeff
Posted: November 15, 2002 at 11:00 PM / IP Logged
YUP...That's source code...too bad I'm too lazy to go through and decipher it...
Hey Verbal....wanna try that again..you can do it.....
Word of advice...don't try using HTML code..jsut good ole normal typing, and if need be copy and paste...you be aight...
Đễẳ†ђş 12\/ Ĵęśŧē®™Sorry, you can NOT post a reply.
Monday, May 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
