will it be enough power?
geloy
Posted: May 09, 2005 at 2:44 AM / IP Logged
i got a planet audio amp 900watt at 2 ohm. i want know if i have a enough power to push this audiobahn alum12q sub.
oh i forgot im still new here...
planet audio amp BB650.1        audiobahn alum12q
Max Power (2 Ohms)       900W X 1                                                      Power Handling: 1000 watts R.M.
RMS Power (4 Ohms)     350W X 1                                        Dual 6 Ohm
RMS Power (2 Ohms)     600W X 1                                        3 Ohm or 12 Ohm Operation
        3" dual 6 ohm voice coil
haemphyst
Platinum - Posts: 5,059
Posted: May 09, 2005 at 6:55 AM / IP Logged
I gotta say this... If that Audiobohm woofer will take a REAL 1000 watts, LET ALONE 1000 watts RMS, I'm sellin' my Eclipse Ti, and buyin those... Audiobohm WAY over-rates their woofers, tho', so there's no danger of THAT happening.
If you parallel the voice coils, a 3 ohm load will net you somewhere in the 500 watt range (with probably a MAX rating around 750 watts or so) - PLENTY to drive a decent subwoofer to very respectable levels. This being said, I wouldn't really trust the PA amp to do that much, I'm just shooting in the dark...
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
