2000 Jeep Cherokee security light
rickgood
Member - Posts: 38
Posted: May 09, 2005 at 10:30 PM / IP Logged
Is a security bypass module required for the 2000 Cherokee. This vehicle has an encoded key.
Thanks Rick
auex
Platinum - Posts: 5,041
Posted: May 09, 2005 at 10:31 PM / IP Logged
Well, what are you trying to install, alarm, rs, or both?
Yes an immobilizer defeat is needed. The best way to integrate into the vehicle's systems is with a module as well since it is databus.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
rickgood
Member - Posts: 38
Posted: May 10, 2005 at 12:10 AM / IP Logged
someone else had installed an alarm in this vehicle 3 years ago. It has been acting up. The company has replaced the module twice under some recall. I now have this vehicle dealing with a no start which has happened 4 times this year. I have an intermittant databus failure and security light flashing . Vehicle will start and shut down after 10 sec. I will use my DRB to check this PCM but was curious if the alarm would work if a bypass module was not installed.
Rick
