05 Ford F-150
Optik
Copper - Posts: 53
Posted: May 12, 2005 at 3:08 PM / IP Logged
I got a guy that has a 05 Ford F-150 it has the 6 speakers I think and has the 6 disk changer with Mp3. He can turn his volume up all the way and it never distorts and sounds pretty good. He is wanting to amp his speakers to get a little more volume from it.He doesn't want to put alot into it because it is a lease. Do you guys have any recomendations on what he could do to get more volume from this stock setup or a way to Amp the stock speakers?
jdog0411
Copper - Posts: 150
Posted: May 12, 2005 at 3:22 PM / IP Logged
You can add an amp to the factory system, you would just need to bypass the factory amp and run speaker level inputs into the new amp and then run speaker wire to the new speakers from the amp. I'm sure the existing system has it's own factory amp or amps, and there might be a passive crossover or two in there too to route sound to various speakers. You may need to research a little of that as well to determine what you want to do.
2004 BMW 325ci.
Alpine CDA-9885
JL 300/4 and 250/1
JL XR 5.25 comps
Infinity Kappa Perfect 12
Optik
Copper - Posts: 53
Posted: May 12, 2005 at 4:08 PM / IP Logged
WEll the problem is its a lease so he doesnt want alot of time or money into it otherwise I would do a complete upgrade. New speakers amps sub but he doesnt want it
jdog0411
Copper - Posts: 150
Posted: May 12, 2005 at 4:26 PM / IP Logged
you should still be able to add the amp and bypass the current equipment without doing any permanent modification. When it comes time to turn the truck back in, he could take the amp out and plug in the original harness and be done with it.
2004 BMW 325ci.
Alpine CDA-9885
JL 300/4 and 250/1
JL XR 5.25 comps
