rsx 2002 wire diagram
strike92901
Member - Posts: 10
Posted: November 17, 2002 at 9:58 PM / IP Logged
  im installing an auto start on my car and need to track down
    some wires
                                tanks
diabloed
Copper - Posts: 133
Posted: November 17, 2002 at 10:26 PM / IP Logged
<>12volts white   +  ignition harness
<>Starter BLACK/ white   +  ignition harness
<>Second Starter none
<>Ignition BLACK / YELLOW   +  ignition harness
<>Second Ignition BLACK/ red   +  ignition harness
<>Third Ignition none
<>Accessory WHITE/ red   +  ignition harness
<>Second Accessory none
Keysense
<>Power Lock WHITE/ blue   -  either kick panel or
Notes: Also found at the multiplex control unit on the back of the fuse box in a 13 pin plug.
<>Power Unlock WHITE/ green   -  either kick panel or
<>Lock Motor yellow/black    driver kick panel
<>Unlock Motor YELLOW /GREEN    driver kick panel
<>Parking Lights+ RED / black    fuse box
<>Parking Lights- blue    headlight switch
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
<>Door Trigger    -  security control unit
Notes: The driver door trigger is green and the passenger door trigger is lt. GREEN/ red. Use both wires and diode isolate each. The security control unit is to the left of the steering column.
<>Dome Supervision comes on with unlock
<>Trunk/Hatch Pin red   -  security control unit
<>Hood Pin GREEN/ black   -  security control unit
<>Trunk/Hatch Release none
Power Sliding Door
<>Factory Alarm Arm WHITE/ red   -  security control unit
<>Factory Alarm Disarm white   -  security control unit
May need to use relay in certain applications.
<>Disarm No Unlock none
<>Tachometer blue    tach test connector
Notes: The tach test connector is behind the driver side headlight.
Wait to start
<>Brake Wire WHITE/ black   +  brake pedal switch
Parking Brake
<>Horn Trigger orange   -  steering column
Notes: The horn trigger at the security control unit is green.
Memory Seat 1
Memory Seat 2
Memory Seat 3
rsx 2002 wire diagram -- posted image.
Immobilizer By Pass : This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U.
