Wiring 3 type r's
Kyel
Posted: May 15, 2005 at 10:06 PM / IP Logged
Basics: 3 Alpine type r (4ohm dual voice coil)
        Viper audio 1200d (made by DEI)
Dilemma:
I am wiring three type r's and i am doing it as pictured. I will post pictures of my custom enclosure tomorrow.
Wiring 3 type r's -- posted image.
but my amp is a DEI (directed, viper etc) and where you connect the power, ground, remote, speaker + - it is not your average screw connecter but a seperate peice that the wire is inserted into and is than plugged into the amp.
my question is as follows.
when i run all three positive and negative wires... they will not fit in the given hole. Could i run them (12 ga) and use a butt connector to splice all three into a single (8-12 ga) wire and run that to the amp?
essentially i would be running three wires the +, or - and than turning them into one wire before entering the amp.
_____________
_____________ [splice] amp (+)
_____________
_____________
_____________ [splice] amp (-)
_____________
or would that restrict them, thanks for your time
Alpine Guy
Platinum - Posts: 2,478
Posted: May 15, 2005 at 10:39 PM / IP Logged
if you follow the directions your showed above you will only have 1 set of wires going to your amp, , i dunno where your getting these 3 wires from.
geepherder
Platinum - Posts: 3,668
Posted: May 16, 2005 at 7:53 PM / IP Logged
Run one long wire from each speaker terminal at the amp to the furthest sub.  Tap into those wires for the other two.
Kyel
Posted: May 17, 2005 at 1:38 PM / IP Logged
so which way would work best out of those two
Alpine Guy
Posted: May 17, 2005 at 5:00 PM / IP Logged
Whell i would do it with 9 pieces of wire like the picture describes.Wiring 3 type r's -- posted image.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
