amp and sub set up
gicts
Member - Posts: 11
Posted: May 16, 2005 at 5:47 PM / IP Logged
I rencently got 2 2 ohm Alpines that are 300 RMS each and a 2 channel amp that 300X2 RMS @ 2 ohms. What ohm load would you recommend I set the subs for?
Ravendarat
Platinum - Posts: 2,806
Posted: May 16, 2005 at 5:52 PM / IP Logged
Well if the subs are 2 ohm and the amp is 300x2 at two ohms i would just wire one sub to each channel and let it rip. It matches up perfect so I think this is a easy choice.
gicts
Member - Posts: 11
Posted: May 16, 2005 at 7:32 PM / IP Logged
just making 100% sure, I should set the ohm load as 2, right? I have heard it should be at 4 as well as 8
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
