Bending Plexiglass?
hot_rod
Posted: May 01, 2002 at 7:12 PM / IP Logged
Does anybody have any tips or tricks to bending 1/4 inch Plexi?
Platinum - Posts: 12,488
Posted: May 01, 2002 at 7:28 PM / IP Logged
If you do not heat the plexi glass first you will end up breaking it in half. Use a small torch to heat the bend area and quickly bend the plexiglass. If you have a plexiglass/lexan bender you will still need to heat it up.
pat28ca
Member - Posts: 45
Posted: May 01, 2002 at 7:29 PM / IP Logged
heat and also patience. do good prep.
HotRod53F100
Copper - Posts: 84
Posted: May 12, 2002 at 2:34 PM / IP Logged
My experience with bending plexiglass involves using a heat gun instead of a torch. This way you have less chance of messing it up. If you don't have a heat gun, Sears sells a thing called a paint burner for about $10 that works just fine. The torch will work too, but you have a chance of burning it with the flame.
HotRod
