Router Circle Cutting Jig?
mob.dynam.grad
Copper - Posts: 73
Posted: May 29, 2005 at 2:30 PM / IP Logged
hey everyone...i finally made a router purchase and i can start cutting some wood more acuratly than with a jigsaw.  While i attended the school in toronto....we used "circle jigs" for cutting speakers holes in the wood. and other materials...now...i'm not to sure how they were made.  I need one and if anyone knows how i can make one or better yet...where i can purchase one....that would be great! I purchased a skil router that came with both punge and fixed bases....1/4" and 1/2" chucks.  I have been to rona...home hardware and all of the above and i can't find one! Any help in locating one of these that will work with my router would be greatly appreciated...thanks alot!
M&mfabrications
Copper - Posts: 95
Posted: May 29, 2005 at 4:28 PM / IP Logged
Jasper circle jig model #200. You can get one from Amazon.com or other places online.
juniorxs
Member - Posts: 26
Posted: May 30, 2005 at 3:50 AM / IP Logged
make one it will cost you hardly anything, i made one that is adjustable out of left over mdf.
mob.dynam.grad
Copper - Posts: 73
Posted: June 01, 2005 at 11:16 PM / IP Logged
make one eh? sounds like a good time...is there a website that explains how or could u explain how u built yours? i have a pretty good idea...i'm just a little stuck as to what to use for the adjustable pin to go into the centre....any ideas?
ajgonzales
Member - Posts: 20
Posted: June 01, 2005 at 11:21 PM / IP Logged
use a piece of a metal dowel/rod thing. a wooden dowel would probably work well too.
auex
Platinum - Posts: 5,041
Posted: June 01, 2005 at 11:25 PM / IP Logged
I make mine out of 1/4 inch plexi. I cut it in the same tear drop shape. Then I cut out and drill the mounting holes for the router. Then I measure and drill holes the radius of the most popular holes that I cut. Make sure that you measure from the center of the router bit to the center of the hole you are drilling. Ir really is just a copy of the jasper one but only with holes that I choose.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
mob.dynam.grad
Copper - Posts: 73
Posted: June 01, 2005 at 11:32 PM / IP Logged
how would i make it so instead of there being a series of holes...there is a slot that i culd slide the dowel piece up and down for all different sizes of holes...something that can be loosened and adjusted and tightened again using the teardrop shape...?
auex
Posted: June 01, 2005 at 11:34 PM / IP Logged
Don't know on that one.
juniorxs
Member - Posts: 26
Posted: June 02, 2005 at 4:04 AM / IP Logged
here is a few pics of the guide i made.
Router Circle Cutting Jig? -- posted image.
joebiv318
Member - Posts: 46
Posted: June 03, 2005 at 11:22 PM / IP Logged
Sears Craftsmen $19 works great
Owner/ Custom Compact Performance
Treo,Cadence,ARC Audio
Critical Mass/Icon TV
Panasonic,Compustar,Scosche
