2001 dodge dakota
accord78
Copper - Posts: 97
Posted: June 05, 2005 at 12:20 PM / IP Logged
sup guys need alittle help. i'm about to install a basic alarm system in this truck i need to know where and how to isolate the door trigger wires since i have to use both of then. next question how to hook up the domelight supervision. thanks
dare_ds69
Silver - Posts: 419
Posted: June 06, 2005 at 7:58 PM / IP Logged
you need to do this
http://directechs.com/techtips/pdfs/resources/security/directed_techtips/1076.pdf
Door Trigger    -  CTM
Notes: The driver door trigger is tan in connector 2, pin 15. The passenger door trigger (and rears on the 4dr) is tan/red in connector 2, pin 13. Use both and diode isolate each. See directfax document #1076 for wiring information.
The Central Timer Module is in the driver kick panel.
Dome Supervision use door trigger
use a relay
30 goes to green wire door triger
87 ground
85 BLACK/ white
8612v fused2001 dodge dakota - Last Post -- posted image.
how own your mind, control your life.
MECP certified. always use a DMM
