1998 honda CRv, APS996A or Viper 791vx?
norris04
Member - Posts: 13
Posted: June 06, 2005 at 3:50 PM / IP Logged
I have a 1998 honda Crv and I want to get a Audiovox APS996A Remote start alarm system or a Viper 791vx.
I want to know which one is betterthe audiovox APS996A or Viper 791VX, because i heard that the viper makes the starter go out quicker than the audiovox
I want to know if its easy for me (a person who has no knowledge, but has a wire diagram)to install
I want to know if i need any extra items in order to complete the installation
Norris04
thepencil
Gold - Posts: 1,526
Posted: June 06, 2005 at 4:21 PM / IP Logged
When you go grocery shopping. You have access to all sort of food that you can make any meal you want. Is it safe to ASS-U-ME that you can cook like a first class chef1998 honda CRv, APS996A or Viper 791vx? - Last Post -- posted image..
Below is what you will need. If you can put the two together I don't see why you can not do it. Ask questions if you are not sure. Lots of Professional installer here to help you out here.
      Viper 791vx manual Viper 791VX install manual
DIRECTWIRE™ WIRING INFORMATION - HONDA / CR-V / 1998 / Remote Start
[PRINT THIS PAGE]
12volts white   +   ignition harness
Starter BLACK/ white   +   ignition harness
Second Starter
Ignition BLACK / YELLOW   +   ignition harness
Second Ignition
Third Ignition
Accessory yellow   +   ignition harness
Second Accessory WHITE/ black   +   ignition harness
Keysense
Power Lock GREEN / WHITE   -   driver door harness
Notes: Must use relays to trigger the lock and unlock wires.
Also found at the green factory alarm plug located in the drivers kick panel.
Power Unlock GREEN/ orange   -   driver door harness
Lock Motor WHITE/ red   5wi drivers kick panel
Unlock Motor blue/red   5wi drivers kick panel
Parking Lights+ RED / black   +   dash dimmer
Parking Lights- blue/red   -
Notes: This wire only works if there is a factory alarm installed. It is at the green factory alarm plug in the driver kick.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light GREEN/ black   +   driver kick, harness to rear
Door Trigger lt. GREEN/ red   -   drivers kick
Notes: Also found at the green factory alarm plug located in the drivers kick panel.
Dome Supervision comes on with unlock
Trunk/Hatch Pin blue/black   -   drivers kick
Hood Pin yellow/red or yellow   -   hood switch
Trunk/Hatch Release yellow   +   release switch
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue   ac   test connector
Notes: Found at the 2-pin tach test connector on the drivers side of the firewall.
Wait to start
Brake Wire GREEN / WHITE   +   cruise control
Notes: The cruise control module is located in the drivers kick panel.
Parking Brake
Horn Trigger gray   -   drivers kick
Notes: May also use blue/green at the steering column, negative trigger.
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.1998 honda CRv, APS996A or Viper 791vx? - Last Post -- posted image.
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
