valet 552T
tabo
Member - Posts: 27
Posted: November 21, 2002 at 7:15 AM / IP Logged
just got it today..  it has two parts..  here is what is written on it..
DEI 710-12 PIN primary HARNESS
(pin out compatible with 437/438/448 Series all outputs limited to 200mA Max)
RED / WHITE (-) OUTPUT Channel 2
RED (+) INPUT 12V Power
BROWN (-) OUTPUT Horn Honk
YELLOW (+) INPUT Switched Ignition
BLACK (-) INPUT Chasis Ground
BLACK/ WHITE (-) OUTPUT Domelight
WHITE/ BLUE (-) OUTPUT Channel 3
WHITE (-) OUTPUT Parking Lights
ORANGE (-) OUTPUT When Armed
1. PIN (blue) PLUG IN VALET/PROGRAM SWITCH
2. PIN (small) PLUG IN STATUS LED (low voltage)
3. PIN: GREEN: (-) LOCK, (+) UNLOCK
BLUE: (+) LOCK, (-) UNLOCK
PGM SWITCH BLUE 2 PIN STATUS LED
MAIN HARNESS - RED PLUG
LIGHT GREEN (-) FACTORY SEC DISARM OUTPUT
BLACK (-) CHASSIS GROUND INPUT
WHITE/ BLUE (-) Activation Input
YELLOW (+) Ignition Output To RF Unit
WHITE (-) Parking Light Output
SECONDARY HARNESS - WHITE PLUG
BLUE (-) Status Output/Fac Sec Rearm
BLUE/BLACK (-) Second Ignition Output
GRAY (-) Shutdown Input
BROWN (+) Shutdown Input
WHITE Tachoometer Input
BLACK/ WHITE (-) Neutral Safety Input
RELAY SATELLITE - WHITE PLUG
RELAY SATELLITE 5 HEAVY GAUGE WIRES
RED (+) Constant 12V Input
PINK (+) Ignition Output
ORANGE (+) Accessory Output
VIOLET (+) Starter Output
why is there two modules?  is one an alarm and the other remote start?  i'm missing two harness can i get them from DEI?  expensive?
Chris Luongo
Platinum - Posts: 3,746
Posted: November 21, 2002 at 5:15 PM / IP Logged
The second part is simply a bank of relays....most other brands build the relays inside the unit.  DEI's method makes mounting the relays a chore, but you can also reconfigure a lot of stuff to make the installation easier.
As for the harnesses you're missing.  Take what you have to the install bay of your local Best Buy or Circuit City-----most installers have all manner of spare parts in their toolboxes.....bring cash.
