00 vw golf problem
takenguitar
Member - Posts: 8
Posted: June 07, 2005 at 12:27 AM / IP Logged
i installed a new deck in a 2000 vr6 gti. the radio works fine , but the problem i have is that after the install the check engine light came on. ive heard of something called a kay wire behind the radio that can cause this problem is this true? if so how can i fix this problem, if not, is there a solution for this check engine light problem? thanks in advance.
mark brasil, alpine 9811, ppi 6600 6ch amp, planet audio comp. set(2), custom built slot portbox,3-4yr old audiobahn alum q 10",ppi 1000 watt amp, 04 scion xa
dwarren
Posted: June 07, 2005 at 12:30 AM / IP Logged
Did you disconnect the battery for the install?
Sometimes disconnecting the battery will solve it or you may have to take it to the dealership for the reset tool.
takenguitar
Member - Posts: 8
Posted: June 07, 2005 at 3:21 AM / IP Logged
unfortunatly no i did not disconnect the battery before the install, but would it be possible to reset the computer after the install has been done, by disconneting the battery?
takenguitar
Member - Posts: 8
Posted: June 07, 2005 at 3:24 AM / IP Logged
also the car had an aftermarket deck already installed in it. it was some cheap sony and we put in an alpine 9855.
takenguitar
Member - Posts: 8
Posted: June 07, 2005 at 3:30 AM / IP Logged
no i did not disconnect the battery before the install, but the car already had an aftermarket deck put in it (some cheap sony) and we put in an alpine 9855.  would reseting the computer by diconnecting the battery work?
