Jeep Cherokee -94
Tong
Member - Posts: 9
Posted: November 22, 2002 at 1:28 AM / IP Logged
Hi, is there anyone who now if Jeep has a alternator cabel to be used for remotestart???  Or if ther is any other way to do it.
/Tong
tong
Sound Pressure
Silver - Posts: 711
Posted: November 22, 2002 at 2:26 AM / IP Logged
???????Alternator cable???? Are you wanting to add a remote start to your Jeep? Do you need the wiring info? If so here is the wiring info.
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1993-94&make=Jeep&model=Cherokee&ID=18132&type=Alarm
Sound Pressure
egtalon93
Member - Posts: 22
Posted: November 22, 2002 at 5:26 AM / IP Logged
|              12V|pink/blk or RED / wht |+  |steering column             |
|          STARTER|yellow/blue (small) |+  |steering column             |
|         IGNITION|blue/gray           |+  |steering column             |
|        ACCESSORY|ORANGE / black        |+  |steering column             |
|       POWER LOCK|ORANGE / purple       |+  |blk conn. drivers kick      |
|     POWER UNLOCK|pink/purple         |+  |or red conn. pass kick      |
| PARKING LIGHTS +|blue/red            |   |left of st. column          |
|       HEADLIGHTS|tan/black           |+  |at switch-high and low      |
|     DOOR TRIGGER|yellow *2           |-  |drivers kick panel          |
|  TRUNK/HATCH PIN|tied in with doors  |-  |drivers kick panel          |
|         HOOD PIN|BROWN / tan           |-  |pass. kick blue plug        |
|  FCTRY ALARM ARM|pink/orange         |+  |pass. kick red plug         |
|FCTRY ALRM DISARM|purple / YELLOW       |-  |driver kick black plug      |
|       TACHOMETER|gray/blue           |   |pcm*1                       |
|       BRAKE WIRE|white               |+  |left of brake pedal         |
|     HORN TRIGGER|gray/orange         |-  |steering column             |
|           WIPERS|BROWN / white         |+  |steering column             |
|  LF WINDOW UP/DN|white - lt. blue    |A  |drivers window switch       |
|  RF WINDOW UP/DN|brn/wht - pur/wht   |A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|blu/wht - RED / blk   |A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|gry/blk - grn/wht   |A  |drivers switch or kick panel|
Notes:
*1 High on passenger side firewall under hood.
*2 Not underdash light
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
