Audiobahn 10 Subs AW101T
MooseRLP
Member - Posts: 11
Posted: June 15, 2005 at 9:13 AM / IP Logged
My friend has a 2004 F-150.  He wants to put some subs in his truck under the back seat.  He already has bought a downfire box for 2 10".  He has a RF 1001BD (1,100 watt RMS) amp and is looking at the Audiobahn subs are 450 RMS because the box can only fit subs 5.5" deep and the subs are 5".  Are these subs any good and do they sound good?
Blowntweeters
Silver - Posts: 650
Posted: June 15, 2005 at 9:48 AM / IP Logged
those subs are over rated ,and that amp is under rated .its not a good combo .look in to subs that can handle a bit more power ,and the lower end Audiobahn stuff that i have installed was not worth the money .as far as the mounting depth go to web sites look at specs. try to find some subs that will work with you max depth and handle about 600 rms . i will look also and get back to you .
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
MooseRLP
Member - Posts: 11
Posted: June 15, 2005 at 10:01 AM / IP Logged
Blowntweeters
Silver - Posts: 650
Posted: June 15, 2005 at 10:38 AM / IP Logged
are you looikg for an SQ sub SPL sub or a well rounded sub
MooseRLP
Member - Posts: 11
Posted: June 15, 2005 at 10:52 AM / IP Logged
He just wants to find some subs to put under his back seat that will be under 5.5" in mounting depth to listen to when he goes on trips with his kids.  He has 2 Kicker 15" CVR (Sit on the rear seat) that he uses right now but he wants something that will stay in the truck when he has to take out the 15" he still has pretty goodd thump.  But the amp is rated at 1,100 watts rms so he will have to adjust his gain so it wont blow the 10"s.  I told him to go with the Kenwood Typhoons (they are 350W RMS a piece)  just turn down his gain so it wont blow. I am just trying to see what other options he has.
Blowntweeters
Silver - Posts: 650
Posted: June 15, 2005 at 10:56 AM / IP Logged
the soundstream van gogh 10"s are a well rounded sub great SQ and good SPL there mounting depyh is 5.4 in you can check them out at www.soundstream.com as fer as the kenwood subs i have not seen any specs or installed any i tryed to check them out but the kenwood site was giving me problems
Paradigm
Silver - Posts: 284
Posted: June 15, 2005 at 11:17 AM / IP Logged
Keep in mind that most subs that are vented out the back of the sub require at least 1/2" of airspace to get proper venting and reduce heat.
VEHICLE: 2002 GMC Sonoma ZR2
Alpine CDA-7940
AudioControl EQT x2
JL Audio 1000/1
JL Audio 10W6 (originals) x3
Kicker ZR120
Kicker ZR460
Polk GXR-6 x4
Polk GXR-4 x2
TruckSystem
Copper - Posts: 185
Posted: June 15, 2005 at 11:45 AM / IP Logged
They make shallow mount depth 5.4 inch Diamond Audio D3 subs as well, I have last years model TM3s in my truck and they sound great. That is a bit too much power for them out of that amplifier however, but it depends what wiring configuration he uses and if that is 1100 rms at 4 ohm or lower.
2003 Chevrolet Silverado Standard Cab ~ Alpine CDA-9851
Diamond Audio D3600.1 ~ 2x Diamond Audio TM310D4
Diamond Audio D3400.4 ~ Diamond Audio Hex S600s
AstroStart RS5204 Remote Start/Alarm
MooseRLP
Member - Posts: 11
Posted: June 15, 2005 at 12:51 PM / IP Logged
if he gets those Kenwoods and turns the gain down on the amp will it still blow the subs?
Blowntweeters
Silver - Posts: 650
Posted: June 15, 2005 at 1:23 PM / IP Logged
that amp is just two much power for both of those the kenwoods and the audiobahns  did you look at the van gogh subs they only need like .5 cubes of air space and there 500 RMS they can handle that power check them out
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
