Lynx 200R M/T Cavalier Z24
any_available
Member - Posts: 16
Posted: May 09, 2005 at 10:39 PM / IP Logged
thank you jeff for pointing out search button but I did the search before posting.
I am using lynx for the first time and it seems to have only 3 wires coming out with 12 volt for starting. for starter,1 ign and ign 2 wich says accessory at same time. now what should i use the 2nd wire for? ign2 or as accessory. the cavalier has 2 ign wires.
please help if you can.
Thank you.
by the way bobk, what do you mean by double post?
Platinum - Posts: 12,488
Posted: May 09, 2005 at 11:07 PM / IP Logged
There's a wire that is used for 2nd IGN on the secondary harness. I can't remember off hand, but what you can also do is use this diagram : http://www.velocitymotorsport.com/images/install_notes/2nd_ignition_relay.jpg
This will give you a second IGN wire to hook up the WHITE wire to.
Posted: May 09, 2005 at 11:16 PM / IP Logged
What do you mean by this ? There is a main harness on the Lynx system that has all the IGN wire that you will need. Read the installation manual and it will tell you all the necessary wires that are required for the remote start to work.
any_available
Member - Posts: 16
Posted: May 12, 2005 at 10:21 PM / IP Logged
Hi guys,
I am trying to install this lynx 2000R into my friend's 1999 Cavalier Z24. on my control module I only have output for ign 1 and the other 1 for ig2 but it says ACC as well for the same wire. does anyone know what is the orange wire Ig 2(ACC) on the module used for. is it really ign or accessory wire?
I will be very thankful to the helper
mo12v
Posted: May 12, 2005 at 10:50 PM / IP Logged
Isn't it programable thru your 2000R for either??
MO
frenchNew
Posted: May 12, 2005 at 11:01 PM / IP Logged
According to the manual, page 10:
IG2(ACC) +12V Output
The + output is used to supply power ti supplementary devices as the heater and air conditioner. Find the wire that supplies power to the heater fan/air conditioner fan or climate control unit. If more than one wire is needed, use a relay.
Best regards from Montreal
Frenchnew
I am busy serving a customer
any_available
Member - Posts: 16
Posted: June 24, 2005 at 8:22 PM / IP Logged
HI guys,
I am having some serious trouble installing this Lynx 2000R on a cavalier. (1) the model is supposed to be for both auto and manual tranny but there are no direct bypass wires for it on the module for the mnual transmission. Also the clutch wires on the switch are both grounded when clutch is not depressed. How do i bypass such system since i loose ground on 1 wire as soon as i press the clutch. (2)HOw many accessory wire do have to connect on this model. I have 2 on the car but have only 1 output wire on the module. (3) Where is the concvenience module located since that's where I will need to connect my door trigger wires.
Please try to help as much as you can.
This is really getting messy
Thank you in advance
mo12v
Posted: June 24, 2005 at 8:25 PM / IP Logged
No guessing..........
What year is the CAV????
MO
any_available
Member - Posts: 16
Posted: June 24, 2005 at 8:29 PM / IP Logged
sorry,
its a 99 2 door with a 2.4
mo12v
Posted: June 24, 2005 at 8:37 PM / IP Logged
U will need a couple of SPDT Relays.  Also pay attention to doorlock instructions
Constant 12 voltsRED & REDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightL GREEN/ BLACK (DR) &L BLUE (ALL DOORS) AT CONV. CENTER *
Trunk Pin SwitchBLACK (+)TRUNK LIGHT
Parking LampBROWN (+)AT HEADLIGHT SWITCH
Power LockL BLUEDRIVER KICK (W/O OEM KEYLESS) **
Power UnlockWHITEPANEL (W/OEM KEYLESS)
* L GREEN/ BLACK (-) Covers Driver Door Only. L BLUE (-) Covers All Other Doors. Diode Isolation Needed, Cathode (Band) Side Of Diode Faces OEM Wires. Convenience Center Module Located Above Passenger Kick Panel. ** Without OEM Keyless Door Lock Wires MUST Be Tested From PASSENGER Switch!!
W/O OEM Keyless ...... Reversal Rest At Ground Door Locks.
With OEM Keyless ...... Positive Pulse Door Locks
Accessories
Window UpD\ D BLUE P\ L BLUE D\ D GREEN P\ L GREEN @ MAIN SWITCH
Window DownF/ BROWN F/ TAN R/ PURPLE R/ PURPLE
Ign Key WarnL GREEN (-)IGNITION SWITCH HARNESS
Trunk ReleaseBLACK/ WHITE (+)AT OEM KEYLESS MODULE *
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsD BLUE (-) (LO) &PINK (-) (HI) AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
Reversal Rest At Ground Power Window Circuit Diagram.
* With OEM Keyless Only!!
OEM Keyless Module Located On Drivers Side Of Trunk.
Remote Start
Tach SignalWHITEAT POWERTRAIN CONTROL MODULE *
Ignition #2ORANGEIGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3WHITEIGNITION SW. HARNESS(PCM & CLUSTER)**
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightL GREEN (+)AT SWITCH ON TRANSAXLE
Rear Window DefrostN/ATIMER BUILT INTO SWITCH
* 2.4L Engine Tach Wire Is WHITE At Powertrain Control Module (PCM). 2.2L Engine Tach Wire Is WHITE or ORANGE At PCM Or Ignition Control Module. Both Wires Are 2 Cylinder Signals Each. PCM On Both Located In Passenger Front Fender. Ignition Control Module On 2.2L Located On Rear Center Of Engine. ** WHITE Wire Powers Powertrain Control Module (PCM) & Instrument Cluster.
G.M. Passlock
MO
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
