Problems with wiring Somewhere..
cpgoose
Gold - Posts: 1,098
Posted: November 27, 2002 at 11:13 AM / IP Logged
my bad, ignore my post.  I wasn't reading correctly Problems with wiring Somewhere.. - Page 2 -- posted image.
Aznpanther98
Member - Posts: 36
Posted: November 27, 2002 at 1:03 PM / IP Logged
yeah check hat switch at the door when i first got my 98 eclipse couple weeks later the door switch on the driver side wouldn't work right unless i wiggle the switch it was b/c the rubber covering the switch it was jamming the switch close but anyways if its not the switch worse case is the wiring along that switch is bad
i duno how to remove it off the accord but can't be that hard? mine is a screw on th switch itself so hope that helps
bozoka45
Member - Posts: 25
Posted: November 27, 2002 at 6:17 PM / IP Logged
I removed the switch and didnt notice anything wrong with it.  It just has one screw holding it in, BTW.  I am going to flop the broken switch with one that I know is working to see if that is my problem.
