91 accord keyless entry
jamminjimbo
Member - Posts: 6
Posted: June 27, 2005 at 11:28 PM / IP Logged
Hello-
I have a 1991 that I'm installing a dei valet 712t keyless entry in, and I wanted to know if i needed to use a relay when wiring up the horn to honk...
Thanks Everyone
thepencil
Gold - Posts: 1,526
Posted: June 28, 2005 at 8:55 AM / IP Logged
Save the guess work, add a relay.
Horn Trigger lt. GREEN/ blue    -   column or horn relay.
HONDA, ACCORD, 1991, Horn Trigger
High-current ground. Use a relay when interfacing with this circuit.
Be careful whose advice you buy, but be patient with those who supply it.91 accord keyless entry  -- posted image.
jamminjimbo
Member - Posts: 6
Posted: June 28, 2005 at 10:40 AM / IP Logged
Thanks!
thepencil
Gold - Posts: 1,526
Posted: June 28, 2005 at 12:52 PM / IP Logged
You are welcome.
jamminjimbo
Member - Posts: 6
Posted: June 29, 2005 at 12:20 AM / IP Logged
I have a DEI Valet 712t keyless entry system, It says it has an onboard relay for domelight supervision. Does that mean i just need to hook up the wire to the door trigger, or is there more to it?? I have a 1991 honda accord if that helps
Thanks all
joe_1
Silver - Posts: 286
Posted: June 29, 2005 at 4:11 PM / IP Logged
if it syas it does than all you have to do is hook up the wire but make sure the suply is what you need being + or - coming from the relay otherwise this will cause you a few problems.
jamminjimbo
Member - Posts: 6
Posted: June 30, 2005 at 2:50 PM / IP Logged
If I use a another relay(just to be safe) would that cause any problems??
mo12v
Posted: June 30, 2005 at 3:06 PM / IP Logged
You don't need a Relay........
Dome LightBLACK/ WHITE (-)BROWN CONNECTOR ABOVE FUSE PANEL *
* Dome Light Also Found As WHITE/ BLACK
MO
jamminjimbo
Member - Posts: 6
Posted: July 05, 2005 at 12:20 AM / IP Logged
Hello All--
ok, the domelight works just fine, but i can't for the life of me find the wire for the horn, could the colors of the wire possibly vary from the wiring guides? Any input would be greatly appreciated!--Thanks!
Powermyster
Silver - Posts: 962
Posted: July 05, 2005 at 4:31 AM / IP Logged
i find wiring colours to be inaccurate at the best of times LOL they are meant as a guide not as gospel.. get thge colour at the horn in the engine bay. make your connection there if you need to
