Grand am lock/unlock
tuckie
Member - Posts: 14
Posted: June 30, 2005 at 12:21 AM / IP Logged
I have a 2002 grand am with a viper 791xv and I am trying to work out the lock unlock scheme. I know that I need to tie the white wire at the bcm to ground for lock, and the same wire to ground through a 1500ohm resistor for unlock. With the viper, there is a green - lock, + unlock wire, as well as a blue + lock, - unlock wire.
are there any good diagrams for this setup? are there any relays/diodes needed for this setup?
Thanks in advance.
mo12v
Posted: June 30, 2005 at 8:12 AM / IP Logged
<<<  I know that I need to tie the white wire at the bcm to ground for lock, and the same wire to ground through a 1500ohm resistor for unlock. With the viper, there is a green - lock, + unlock wire, as well as a blue + lock, - unlock wire.  >>>
The BLUE wire from Viper goes to 1.5 ( 1500)ohm Resistor then to WHITE wire on G.A.
The GREEN wire from Viper goes to WHITE wire on G.A. also.
You may need Relays to supply stronger Ground if that doesn't work.
MO
tuckie
Member - Posts: 14
Posted: June 30, 2005 at 8:30 AM / IP Logged
Do you think diodes are needed so it doesn't send power up the other wire?
mo12v
Posted: June 30, 2005 at 8:46 AM / IP Logged
NO
MO
thepencil
Gold - Posts: 1,526
Posted: June 30, 2005 at 9:31 AM / IP Logged
Single wire lock/unlock system.
Be careful whose advice you buy, but be patient with those who supply it.Grand am lock/unlock -- posted image.
Thursday, July 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
