Aussie Ford capri Door Locks
Spiderman68
Member - Posts: 10
Posted: July 10, 2005 at 4:22 AM / IP Logged
Hi all
Be nice i am new.....
I have fitted a RHINO RA alarm to my Ford (Mercury) Capri 1993 XR2... I am having big problems with the door locks...The doors have switches in each door console .the ,otors are both slaves and they both work of each button eg lock with one locks both..they work on a reverse power principle eg lock supplies pos and neg to the motor..unlock suplies the power opposite....
My problem is i use the -ve unlock/lock signal for the locking of the doors ....i have used the 4 relay setup that i found on this site......when i use an earth i select the doors lock and unlock but when i use the alarms trigger it is not powerful enough to latch the relays long enough to power the door locks.....help me please i do not want to put a central locking kit in and loose my switch control i want to keep it original
thanks
webby
xtreme069
Copper - Posts: 67
Posted: July 10, 2005 at 6:25 AM / IP Logged
if you look in the vehicle wiring pages on this site the mercury capri 1993 needs an actuator in the drivers door then you use a reverse polarity relay setup so your alarm will drive the actuator you only need to add the actuator in the drivers door so that when the actuator pushes the lock rod the passenger door opens not sure why you decided to use the 4 relay setup? good luck
I Love This Industry!!
Spiderman68
Member - Posts: 10
Posted: July 10, 2005 at 6:43 AM / IP Logged
I would say it quotes that cause the mercury does not have locking central switched in the USA model????
mine has slave motors that operate off a switch and the lock unlock wires are pink/black and pink orange
Webby
maybe i should use the next relay config under tha 4 relay one on this site
xtreme069
Copper - Posts: 67
Posted: July 10, 2005 at 7:19 AM / IP Logged
that could work but it may only drive one of the doors what do the pin/black and pink/orange rest at?
Spiderman68
Member - Posts: 10
Posted: July 10, 2005 at 7:22 AM / IP Logged
those two wires rest at nothing and they control both doors
xtreme069
Copper - Posts: 67
Posted: July 10, 2005 at 7:27 AM / IP Logged
just getting this straight you have one switch on the console that locks and unlocks both doors?
Spiderman68
Member - Posts: 10
Posted: July 10, 2005 at 7:32 AM / IP Logged
no one switch on each door which locks and unlocks both doors........
xtreme069
Copper - Posts: 67
Posted: July 10, 2005 at 7:48 AM / IP Logged
ok after checking the locking configurations it sounds like your first relay config was correct cause you said it worked but only if you used a strong ground so although this sounds a little over the top you need to use 2 more relays to strengthen the lock unlock outputs or if it truly only needs a longer output then most alarms will allow you to extend the lock/unlock output from less than a second to about 3.5 seconds to accomadate the vaccum locks on a merc hope this helps don't think the 5 wire configuration will work cause for it to work the pinks need to rest at something let me know how you go and good luck
Spiderman68
Member - Posts: 10
Posted: July 10, 2005 at 6:53 PM / IP Logged
Hi Thanks
I want to get away from using 6 relays as i will have no room for a passenger soon...
Any other ideas
Webby
Spiderman68
Member - Posts: 10
Posted: July 11, 2005 at 7:11 AM / IP Logged
Gday
If your interested i got it fixed.....i used the 5 Wire Alternating 12 Volts Positive Door Locks relay config from this site...had to wire it right near the drivers switch
Tuesday, December 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
