Nitrous oxide wiring
allkiller
Posted: July 12, 2005 at 3:39 PM / IP Logged
Please can you suggest a relay wiring for my nitrous set up, there are two solenoids that have to be switched on after first arming the system, followed by the full open throttle micro switch activation and then the momentary activate switch on the gear stick. any Ideas ??
one04fx4
Member - Posts: 8
Posted: July 17, 2005 at 7:49 AM / IP Logged
what year vehicle is it going on. new or old. if is old the best way i have found is to wire two switches. one on the clutch and one on the gas. if it is new they make switches for this to run off the tps switch. all you will have to do is lift the pedal a little and it will shut it off
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
