kill switch
sparkyspider
Member - Posts: 7
Posted: July 21, 2005 at 6:17 PM / IP Logged
If I wanted to install a starter kill switch, would I need a relay? If so I diagam would be nice...:)
Powermyster
Silver - Posts: 962
Posted: July 22, 2005 at 5:00 AM / IP Logged
find the starter wire. cut it.
and wire relay like so.
SPDT RElay.
87A - Not used.
87  -  starter side of starter wire.
30  -  Ignition side of starter wire
86  -  12V constant.
85  -  earth.  put the kill switch on this wire between. solid chassis ground and relay..
all done.   take you about 20 mins
thepencil
Gold - Posts: 1,526
Posted: July 22, 2005 at 9:01 AM / IP Logged
Starter Kill Wiring Diagram
Be careful whose advice you buy, but be patient with those who supply it.kill switch -- posted image.
Powermyster
Silver - Posts: 962
Posted: July 22, 2005 at 11:37 AM / IP Logged
is that not what he wants a kill switch..
Powermyster
Silver - Posts: 962
Posted: July 22, 2005 at 11:49 AM / IP Logged
so i'm right for once..   COOL!!
thepencil
Gold - Posts: 1,526
Posted: July 22, 2005 at 12:27 PM / IP Logged
You are right bobk, No alarm follow Powermyster instruction. If you got an alarm follow my diagram.
sparkyspider
Member - Posts: 7
Posted: July 22, 2005 at 1:38 PM / IP Logged
Im trying ti understand, why, just for a kill switch do I need a relay? I dont have an alarm,and want to put a kill switch untill I get an alarm. Whu can`t I just cut the ignition wire,put switch in and be done?
sparkyspider
Member - Posts: 7
Posted: July 22, 2005 at 2:33 PM / IP Logged
Thanks for the info. I have a lot to learn...:)
Powermyster
Silver - Posts: 962
Posted: July 23, 2005 at 6:33 AM / IP Logged
also you will need a big switch to kill starter to switch a relay you can have a little small hidden switch..
