Compustar CM3000 in 1989 Pontiac GTA
wobeking
Posted: July 24, 2005 at 11:55 PM / IP Logged
hello, hope you can help me, i bought the cm3000 and decided to install myself, i have it about 60% installed and i have it working to some extent. I'm having trouble with a few things... 1. my power door locks don't lock and unlock when i arm/disarm. 2. trunk doesn't pop when using remote. 3 system thinks doors are open when i arm and alarm does not activate when door is opened. 4. the remote start doesn't function because of chip in key that needs to be in ignition to start motor, any way to bypass that problem, motor will remote start if the key is just inserted into ignition and in off position. 5. what do i do with the following wires?
connector #1, purple pigtail wire and blue wire coming off of second relay
connector #2, i don't know where any of the wires on connector 2 go?? please help
connector #3, pin #1 i don't have hooked up, should i hook it up anyway. (automatic tranny in car)
pin #5 and 6 i have hooked up to the (-) and (+) of the floor lights that some on when the door is opened but i think something might be wiring because the system thinks the door is still open when i arm it even though the lights are off.
connector #4, pin #2 i have this wire hooked up to the brown trunk release wire at the switch and my trunk doesn't open with the remote??
pin #4 i have hooked into the light blue lock wire and pin #5 is connected to the black unlock wire and locks don't work, please help??
connector #5 pin #1 and #2 and #3 i don't know where to hook them up, please help?
pin #6 and #7 i don't have any need for aux i don't think
i also have a proximity sensor any help with wiring that would be nice too. it has a red (+) 12v black (-) and a orange trigger wire.
all and any help would be greatly appreciated
thepencil
Gold - Posts: 1,526
Posted: July 25, 2005 at 8:17 AM / IP Logged
Is this a Grand Am Vehicle? I might be able to help you out. I know a thing or two about remote starter.
Be careful whose advice you buy, but be patient with those who supply it.Compustar CM3000 in 1989 Pontiac GTA -- posted image.
Platinum - Posts: 12,488
Posted: July 25, 2005 at 9:01 AM / IP Logged
thepencil, this is the Firebird GTA.
You need to add relays to convert the (-) signal from the CM3000 to (+). Use this diagram: http://www.velocitymotorsport.com/images/install_notes/N2P.jpg
The trunk release is a (-) trigger and you will need to use a relay to boost the 250 mA signal from the CPU to operate the trunk release. Use this diagram: http://www.velocitymotorsport.com/images/install_notes/N2N.jpg
wobeking wrote:
3. system thinks doors are open when i arm and alarm does not activate when door is opened.
The door trigger wire is WHITE at the courtesy light and is a (-) trigger. Make sure that you use the RED / WHITE wire from CN3 and NOT the RED wire from CN3 otherwise you will experience this problem.
GM VATS bypass Part 1     /      GM VATS bypass Part 2
The two wires will not be used on this relay because you don't have a 2nd ACC , Starter or IGN wire. Tape off and do not use. You can remove the relay and use it for the trunk release though.
The only one that you need to use is the BLACK wire. This will turn on and off the VATS bypass wire from the above diagram. This is considered your ground out when running wire. Tape off the other wires , they will not be used.
LIGHT BLUE wire doesn't need to be hooked up if this is a automatic vehicle.
Refer to PROBLEM 3 from above. this is why your having falsing problems. USE ONLY ONE door trigger input from CN3 plug.
Refer to PROBLEM # 2 from above. You need a relay.
Refer to PROBLEM # 1. You need to reverse the polarity of the triiger on the CPU to accomodate the (+) of the vehicle.
You do not need to hook up pin # 1 or # 2 because there is no OEM alarm system on the GTA. The Dome light wire is optional and you need to hook up a relay for this to work if you want dome light supervision after you arm and disarm the car. Use this diagram and use the (-) version : http://www.velocitymotorsport.com/images/install_notes/105.jpg
This is used for any AUX device that you want to have controlled via the remote control. Window modules, lights, hood lock, etc.... the possibilities are endless.
wobeking
Posted: July 25, 2005 at 9:55 AM / IP Logged
thankyou so much, you had my question answered by the time i woke up thismorning now im on my way outside to work on it!! thankyou again!!!!
Posted: July 25, 2005 at 9:56 AM / IP Logged
No problemo
wobeking
Posted: July 25, 2005 at 10:20 AM / IP Logged
any specific kind of relay i should get?
Powermyster
Silver - Posts: 962
Posted: July 25, 2005 at 10:37 AM / IP Logged
SPDT RElay
wobeking
Posted: July 25, 2005 at 12:44 PM / IP Logged
ok so far so good, what do i do with the red wire then from CN3??
wobeking
Posted: July 29, 2005 at 7:50 PM / IP Logged
i still cant get my trunk relay to work, i have the trunk release wire connected to the negative input in the diagram and the rest of it wired accordingly using the negative to positive wiring picture, then i have the +12 output to the brown with white stripe wire wire behind the switch. when i activate the trunk release from the remote the relay clicks  and there is +12 on the output wire so im thinking maybe i have the output on the wrong wire.
Posted: July 29, 2005 at 11:53 PM / IP Logged
The RED wire at CN3 is only for (+) type door trigger systems.
