mercedes ML 320 keysense wire
Johnnynguyen20
Copper - Posts: 89
Posted: July 27, 2005 at 9:07 AM / IP Logged
Hello, my mercedes ML 320 got a KEySENSE wire. the diagram said this wire requried to remote start. Can you help me with this, What wire from remote start should i connect to the KEysense wire?
Johnnynguyen
Moderator - Posts: 12,488
Posted: July 27, 2005 at 9:17 AM / IP Logged
It is the ORANGE wire at the ignition key switch and this is a (+) input. You will need a relay to convert this signal over if your using a universal bypass module or if the bypass module accepts both (-) & (+) then change the jumper over to (+).
Johnnynguyen20
Copper - Posts: 89
Posted: July 27, 2005 at 8:33 PM / IP Logged
So, from the bypass module there is two wires from it. one is (-) and (+)  which one i have to convert to?
Johnnynguyen
mo12v
Posted: July 27, 2005 at 8:51 PM / IP Logged
Depending on your ByPass unit........You would use the ( + ) Positive
MO
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
