92 Park Ave alarm wiring
jeffbayne
Member - Posts: 6
Posted: July 30, 2005 at 1:01 PM / IP Logged
Hi, i need the alarm diagram for a 92 Buick Park Avenue.  I see a 94, but nothing for a 92.  Is it by chance the same?  Thanks
jeff
ECD 416~*~5061~*~Kimber Select~*~DAC 348~*~PA2~*~XM3~*~202m~*~160-03kx~*~NX-30~*~DDC-R17F~*~ZR600~*~88120dvc~*~Zeronoise~*~Yellowtop
thepencil
Gold - Posts: 1,526
Posted: August 02, 2005 at 9:40 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - BUICK / PARK AVENUE / 1992 / Security
12volts red    +   ignition harness
Starter yellow    +   ignition harness
Ignition pink    +   ignition harness
Power Lock lt. blue    +   either kick panel
Power Unlock black    +   either kick panel
Lock Motor gray      drivers door harness
Unlock Motor BLACK/ lt. green      drivers door harness
Disarm Defeat tan      passengers door harness
Parking Lights+ brown      low in drivers kick
Notes: Also found at the lighting control module. The lighting control module is located to the left of steering column.
Parking Lights- dk. blue      light switch
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger white    -   under dash light
Dome Supervision use door trigger
Trunk/Hatch Pin black    -   at switch or light
Notes: Not available on all models.
Hood Pin
Trunk/Hatch Release lt. blue or blk/wht    +   at release switch
Power Sliding Door
Factory Alarm Arm yellow    -   drivers door harness
Factory Alarm Disarm lt. green    -   drivers door harness
Disarm No Unlock
Tachometer PURPLE / white   AC   ignition module
Notes: May also be found white at the instrument cluster on models with a tachometer.
Horn Trigger black    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
VATS
Part #: 652T resistor pack
Notes: See DirectFax document 1049 for interface information.
Be careful whose advice you buy, but be patient with those who supply it.92 Park Ave alarm wiring -- posted image.
jeffbayne
Member - Posts: 6
Posted: August 02, 2005 at 6:10 PM / IP Logged
Perfect!! Thanks!
jeff
thepencil
Gold - Posts: 1,526
Posted: August 03, 2005 at 8:25 AM / IP Logged
You are welcome.
