Just so I’m sure on this connection
Sad, little man
Copper - Posts: 125
Posted: August 03, 2005 at 6:47 PM / IP Logged
I'm trying to figure out how I can integrate some of the wiring from a factory alarm my car used to have into a new aftermarket one. I've found wires for the horn and parking lights that each show 12V then drop to 0V when the switch is on. This would be considered showing ground when the switch is on, right? So should I connect these wires to the new alarm wires that output a ground when it wants these acessories on?
Teamrf
Gold - Posts: 1,031
Posted: August 03, 2005 at 6:54 PM / IP Logged
What kind of car are you talking about?
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Sad, little man
Copper - Posts: 125
Posted: August 03, 2005 at 7:50 PM / IP Logged
It's a '96 mazda miata, but don't go by any published wiring diagrams on it, because the alarm is dealer installed and you won't find it in any diagram. I just want to know if running these wires to the negative outputs on the alarm will make the acessories work like they should.
swamprat323
Gold - Posts: 1,335
Posted: August 03, 2005 at 8:51 PM / IP Logged
why dont you forget about the dealer alarm and just use a wire guide and be done with it.
Waht have you not connected yet.
swamprat323
Gold - Posts: 1,335
Posted: August 03, 2005 at 9:02 PM / IP Logged
your dealer alarm may have been fused, if he/she did it right it will. if for soem reason your alarm stops working for what ever reason you may have to find the fuse soem were on the dealer alarm. skip the future head achs and skip the dealer thing all togheter.
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
