1998 golf III alarm info?
ticoracer
Member - Posts: 7
Posted: August 05, 2005 at 2:10 PM / IP Logged
wazz up !
i'm new on this forum and i'm not an electrician by trade. but i'm one of those do-it-yourself kind of guy. anyways the factory alarm on my 1998 golf gl mk3 2.0 liter engine witha 5 speed manual is not working and i'm planning in using an aftermarket one (maybe a viper brand one) i was just wondering if i have to hook up anything to the oem factory module wiring or just the power lock unit ( the central locking system on my vw is vacuum set up)? if so, can somebody please explain or send me a diagram of which wires do i have to hook up to the vacuum unit thanks!
tico loco
thepencil
Gold - Posts: 1,526
Posted: August 05, 2005 at 2:39 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - VOLKSWAGEN / GOLF III / 1998 / Security
12volts red 10 ga.    +   ign. harness - big
Starter RED / black 10 ga.    +    loop at back of
Ignition black 16 ga.    +    fuse box
Power Lock yellow/red or gray    +   driver door harness in kick
Power Unlock RED / black or grn    +   driver door harness in kick
Notes: Requires a double pulse to unlock.
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+ gray/red, gray/black      back of lt.switch
Notes: Hidden release tab for light switch on upper left side of switch. Use relays to isolate the switch side of parking light wires from seeing 12v, or the igniton circuit will pulse with the light flash. It is also possible to use the hazard lights. The colors are BLACK/ white and BLACK/ green, and are positive trigger. They can be found at the alarm module or steering column.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger BROWN / white    -   dr. kick or alarm mod
Notes: The alarm module is located behind the headlight switch.
Dome Supervision
Trunk/Hatch Pin BROWN / black    -   dr. kick or alarm mod
Hood Pin BROWN / red    -   behind fuse box
Trunk/Hatch Release gray      switch
Notes: Gray wire grounded by switch at rest. Use a relay to isolate the switch side of the trunk release wire from seeing 12v.
Power Sliding Door
Factory Alarm Arm same as lock    +
Factory Alarm Disarm same as unlock    +
Notes: Use a single pulse to disarm without unlocking.
Disarm No Unlock
Tachometer BLACK/ red   AC   at coil on firewall
Horn Trigger BLACK / YELLOW    +   behind fuse box
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.1998 golf III alarm info? - Last Post -- posted image.
Wednesday, May 1, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
