Clifford 3.5 RS problem
dnt408
Member - Posts: 26
Posted: August 06, 2005 at 7:08 PM / IP Logged
Okay, I think the manual is out of date or incorrect. Anyways if I read the step by step instruction on the primary harness, the H1/6 Blue. that wire is suppose to be a multiplex zone 4. So I decided to install my 508D prox sensor there. But the problem is that it's showing up on my remote as a trunk. Not a problem about that but won't do warn, only Full Trigger. I look in the back where the picture is and that wire is for trunk, which makes sense now because it's wouldn't do warn and full.
Anyways, which wire would I need to use in order to trigger senor 2 on my remote. I see that the shock sensor is senor 1 on my remote
dare_ds69
Silver - Posts: 419
Posted: August 08, 2005 at 6:14 AM / IP Logged
the shock sensor wires has an extra green wire wich is not conected to anything thas the wire that you need.Clifford 3.5 RS problem -- posted image.
how own your mind, control your life.
MECP certified. always use a DMM
