Dimesion for 12w3 d6
Aeo37
Posted: August 10, 2005 at 6:37 PM / IP Logged
I am planning to build a ported box for  jl 2 12w3 d6 subsout of mdf , but dont know dimensions for the box.  The trunk space i have to work with it is 31"w x 18"h x 20"-22"d. can someone help me with the demnsions? i tried the winsd, but did not understand it. thanks a lot for the help
Aeo37
Posted: August 11, 2005 at 4:44 PM / IP Logged
bump...help anyone, i need to build this box asap
abovestock
Copper - Posts: 247
Posted: August 12, 2005 at 2:33 AM / IP Logged
look on JL's web sight or call a store that sells JL.
boulderguy
Silver - Posts: 510
Posted: August 12, 2005 at 2:41 AM / IP Logged
JL's site has great box plans if you dig around on there.
Aeo37
Posted: August 12, 2005 at 3:19 PM / IP Logged
thanks for the replies. On JL's site they only give dimensions for 1 sub and I want to do two subs in the limited space i have.
abovestock
Copper - Posts: 247
Posted: August 13, 2005 at 11:38 PM / IP Logged
multiply by two.
Aeo37
Posted: August 14, 2005 at 2:35 AM / IP Logged
then that won't fit my trunk now more
abovestock
Copper - Posts: 247
Posted: August 14, 2005 at 6:22 PM / IP Logged
You don't need to use the exact dimentions. You need the volume but it can be almost any shape to fit your trunk.
Aeo37
Posted: August 18, 2005 at 1:47 AM / IP Logged
ok thanks for all the replies. I am now changing my plan to only using one sub, so that means that I can follow through with the plans jl had for it ported. Only thing now is that i ned your opinion on the hifonics tx1005d and the tx1505d amp. I am wondering if hifonics are good amps to push my sub in a ported box. thanks
