keyless entry
mini14
Copper - Posts: 120
Posted: August 15, 2005 at 5:26 PM / IP Logged
I have a 2003 jeep liberty and got a viper alarm installed in it. I have the product number of the alarm in my garage, so i can get it upon request. The place that installed it said it was $50 more to install the keyless entry. Right now i can arm and disarm the alarm, but I have to use the OEM keyless entry. So it's kind of awkward switching from remote to remote. I have no idea as how to do this. I am a car audio buff, not alarms. I know a lot about car audio so this may not be hard for me to pick up. I have this 96-98 grand cherokee interface module made by dei is there any use for it at all?
Platinum - Posts: 12,488
Posted: August 15, 2005 at 6:27 PM / IP Logged
The Liberty uses a Type F system and you will need two relays and resistors to accomplish keyless entry with the Viper system. Use this diagram for the relays :
http://www.velocitymotorsport.com/images/install_notes/144.jpg
Lock is negative trigger thru a 1.4K ohm resistor and unlock is negative trigger thru a 426 ohm resistor.  MUST use relays. PINK/PURPLE wire is located in the top left corner in a black plug. If you have a Directed 457C or 456L interface module you can use this instead of the relays
mini14
Copper - Posts: 120
Posted: August 15, 2005 at 6:30 PM / IP Logged
Thanks, where is a good place to find info on alarms and what not? I'm trying to learn all aspects of car customization.
dare_ds69
Silver - Posts: 419
Posted: August 15, 2005 at 6:31 PM / IP Logged
Power Lock pink/purple  -  back of fusebox
Notes: Lock is negative trigger thru a 1.4K ohm resistor and unlock is negative trigger thru a 426 ohm resistor. MUST use relays.
In the top left corner in a black plug.
Can also use Directed 457C or 456L interface modules.
Power Unlock same wire as power lock
the 457c will do everything power locks and factory arm and disarm
how own your mind, control your life.
MECP certified. always use a DMM
Posted: August 15, 2005 at 6:38 PM / IP Logged
You've found the best place onthe internet right here keyless entry -- posted image. Post your questions or browse the site and you'll find all you need to know.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
