adding actuators
rabbit713
Member - Posts: 6
Posted: August 24, 2005 at 8:06 PM / IP Logged
is this wiring diagram correct?  cause i tried it and it only unlocked.  (i think pins 86 go together instead of 86 to 85.)
Rabbit713
auex
Platinum - Posts: 5,041
Posted: August 24, 2005 at 8:14 PM / IP Logged
I don't know? There is no diagram or link,
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
rabbit713
Member - Posts: 6
Posted: August 24, 2005 at 8:19 PM / IP Logged
oh my bad i forgot to do that...........well here it is
https://www.the12volt.com/doorlocks/page3.asp#arp
Rabbit713
auex
Posted: August 24, 2005 at 8:23 PM / IP Logged
Yes this diagram is correct.
adding actuators -- posted image.
Pins 85 and 86 are not polar in most cases and it doesn't matter what goes where but that diagram is correct. I would check the wires and make sure you have +12V going to pin 87 of the lock relay and the alarm is sending out the pulse to the lock relay.
rabbit713
Member - Posts: 6
Posted: August 24, 2005 at 8:27 PM / IP Logged
oh thanks....maybe its because i was testing this on a bench multimeter and power supply.   but the unlock output was working)   does this type of testing matter
Rabbit713
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
