Tach, 1999 Ford F-150
glacious
Member - Posts: 13
Posted: September 10, 2005 at 5:23 PM / IP Logged
I currently have a 1999 Ford F-150 with a V6. Since that model didn't come with a tach, I have been wanting to install an aftermarket one. I have looked high and low as to how to install one. I am not sure of xactly what wires I would need to tap into, or if I just need to get an adapter for it. Or if I even need an adapter. So, with that said and done, I was wondering if anybody out there has installed a tach on a similar year truck, or even on just a plain V6. Heck if you have installed an aftermarket tach period, please let me in on how and what you needed to complete the installaiton procces. Thanks a bunch~~
jp
thepencil
Gold - Posts: 1,526
Posted: September 13, 2005 at 12:24 PM / IP Logged
FORD, F SERIES LIGHT DUTY, 1999, Tachometer
Tach wire: on the 4.2L it is a dk. blue/lt. green at the coil pack on top of the motor. On the 4.6L it is a pink/white in a 3 pin plug at the front of the motor below the air intake and next to the fan. On the 5.4L it is a lt. GREEN / WHITE at the coil on the passenger side of the motor between the fuel injectors
Be careful whose advice you buy, but be patient with those who supply it.Tach, 1999 Ford F-150 -- posted image.
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
