Horn Honk?
hot_shot_guy123
Copper - Posts: 114
Posted: December 05, 2002 at 6:28 PM / IP Logged
O.k. thanks 12volt, I'll give it a shot with just running the horn wire to the steering column then if that don't work, i'll hook up the relay to send the (-) signal.  Thanks for your help.
"Light travels faster then sound, that's why some people seem bright until you hear them speak."
hot_shot_guy123
syndicate2323
joelr7309,
Sorry to bother but I'm new to the forum as you can tell and Im kinda confused right now. Horn Honk? - Page 2 - Last Post -- posted image.  Am I supposed to get a Relay, and will it show the terminal numbers as indicated in your diagram??  Or should there already be a relay somewhere in the vehicle?  Can I get this relay at any auto-parts store?  Need Help!!!!!  Horn Honk? - Page 2 - Last Post -- posted image.
Ernie
joelr7309
Copper - Posts: 97
Posted: December 05, 2002 at 8:06 PM / IP Logged
Well What me and Cpgoose did to have the horn and the alarm to go off when triggered is,  like the diagram, WE both have a Viper 550esp, hook up the siren red wire to the diagram show, jumper the wire, and do the relay like showen,    whats cool is that when you press arm/disarm, it just chirp without the horn, but when triggered, both goes off and really loud,  you need
30 amp relay,     2 prong flasher.  you can get it at a auto store or PEP BOYS or Radio Shack,   JUmper  87 and 85 to ground,
86 (+) to siren
87 (-) to ground
30 (x) flasher
85 (-) ground too
 Flasher  (L)  to (+) horn    95 INTEGRA
Horn WireBlue/Green (-) Steering Column
the rookie!~
joelr7309
Copper - Posts: 97
Posted: December 05, 2002 at 8:16 PM / IP Logged
look for the Horn near the steering wheel, there should be 3 wires, look for the blue/green, use a Digital Meter and look for a (+) connect (L) to that
the rookie!~
syndicate2323
Posted: December 06, 2002 at 8:31 PM / IP Logged
joelr7309,
So I would follow this same setup even though I have a "Cliffoerd 9000"
joelr7309
Copper - Posts: 97
Posted: December 09, 2002 at 12:37 PM / IP Logged
yes, depending on what the horn takes, If its a (-) output  do vice versa with the relay
the rookie!~
joelr7309
Copper - Posts: 97
Posted: December 09, 2002 at 12:39 PM / IP Logged
Let me take that back, It's a (-) neg output your looking for, It should be the same with you syndicate2323, if you have the same a alarm, what type of car are you trying to put it on?
the rookie!~
syndicate2323
Posted: December 09, 2002 at 6:53 PM / IP Logged
I have a 1995 Acura Integra and currently have a Clifford 9000 installed.  Would it work???
Ernie
Syndicate C.C. #23
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
