Sunroof closure?
xjr41
Member - Posts: 12
Posted: September 12, 2005 at 9:23 AM / IP Logged
Hi,
Can anyone help?
I have a 1991 Nissan 200SX turbo (240SX in the US) with an aftermarket electric sunroof. The sunroof is wired to constant 12v.
The car has a Clifford Concept 300 with SmartWindows4 and Intellistart.
How can I connect the sunroof to the window closure so they  all shut together?
Do I need to utilise a window closure module (DEI529T or similar) or is there a relay driven solution I could use?
Any info would be great.
Thanks,
Steve.
xjr41
Member - Posts: 12
Posted: September 12, 2005 at 9:33 AM / IP Logged
Just seen the DEI530T.
Am I right in understanding that this could shut the sunroof and also vent the sunroof in co-ordination with venting the windows via the SmartWindows4? How would I wire it up with the SmartWIndows? Could I just tap into the command wires on the SmartWIndows?
Thanks.
ringojam
Copper - Posts: 215
Posted: September 13, 2005 at 3:22 PM / IP Logged
Use a channel on the clifford with a timed curcuit and a relay and do it for closed only .
xjr41
Member - Posts: 12
Posted: September 13, 2005 at 3:44 PM / IP Logged
I thought about that but both timed outputs are being used. I have one negative when armed out put and was gonna use this with the 529T. Is this ok?
