Starter disable on Ranger
jumargibbs
Member - Posts: 24
Posted: September 12, 2005 at 9:34 AM / IP Logged
Thanks for responding, MO
I double-checked and there are indeed two RED / Light Blue starter wires. When the key is turned to "Start", they each read 12V. In fact, they are both crimped into the same connector at the ignition switch. I'm assuming I need to put the starter disable relay between both wires, but seeing as how the alarm works fine up to this point, I will wait to hear back from someone before I risk frying it.
Thanks,
Ken
Ken
ccroadshop99031
Copper - Posts: 102
Posted: September 12, 2005 at 5:28 PM / IP Logged
if it says it has 2 starter wires then the best thing to do is to add a relay to both if they are seoperate if the meet at a visible point then 1 is enough
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
