Alarm power door locks
estical
Posted: September 12, 2005 at 5:20 PM / IP Logged
Hi guys,
I have a 2003 ranger xlt with power doorlocks. I am installing an aftermarket alarm that has the ability to lock and unlock the doors. I was wondering which wiring diagram i need to follow though when hooking it up.
3 wire negative
3 wire positive
4 wire reversal
5 wire alternating
ccroadshop99031
Copper - Posts: 102
Posted: September 12, 2005 at 5:26 PM / IP Logged
12volts      yellow       +       ignition harness
Starter      RED / lt. blue       +       ignition harness
Second Starter      N/A
Ignition      lt. GREEN/ purple       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      gray / YELLOW       +       ignition harness
Second Accessory      BLACK/ lt. green       +       ignition harness
Keysense
Power Lock      pink / YELLOW       -       driver door harness or PKP
Power Unlock      pink/lt. green       -       driver door harness or PKP
Notes: The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1093.
Lock Motor      pink/black       5wi      driver door harness
Unlock Motor      RED / orange       5wi      driver door harness
Parking Lights+      brown       +       headlight switch or GEM
Notes: The GEM (Generic Electronic Module) is to the left of the radio.
Parking Lights-      N/A
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light      BLACK/ pink       +       under driver seat
Door Trigger      yel/blk (L), gry/red (R)       -       GEM
Notes: The driver door trigger is yellow/black and the passenger door(s) is gray/red. Use both wires and diode isolate each from the GEM, refer to DirectFax document 1076.
Dome Supervision      use door trigger
Trunk/Hatch Pin      N/A
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer      tan / YELLOW       ac       instrument cluster or PCM
Notes: The PCM (Powertrain Control Module) is on the top of the firewall under the hood towards the passenger side. The tachometer wire is in pin 48. Can also get tach at the ignition coil or coil pack. Use any of the tan/stripe wires.
Wait to start      N/A
Brake Wire      lt. green       +       brake pedal switch
Parking Brake
Horn Trigger      yellow/lt. green       -       steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
SecuriLock
Part #: 556SW
Alternate Part1 #: 556UW
Alternate Part2 #: 555U
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes:
