Q about head unit install?
ice8168
Copper - Posts: 52
Posted: September 18, 2005 at 9:15 PM / IP Logged
I am about to put an aftermarket head unit in my truck (04 silverado 2500).  I know that I will need an wiring adapter as well as box to keep my chime and RAP.  Where can I find these items the cheapest?  I found a class2 box for around $100 is that about right?
Also when I intall the head unit (Clarion DXZ945MP) I would like to also install a Clarion1/2 DIN EQ.  Does anyone make an install kit theat will accept a 1 Din head unit and a 1/2 DIN EQ?  If so were can I get one.  If not how do I go about building one myself?
Thaks
dmielken
Copper - Posts: 63
Posted: September 19, 2005 at 11:25 AM / IP Logged
Well as far as the parts you need and pricing, the class2 integration unit sells for about 150.00CAN at the box stores here, it is essentially the wiring harness, and then you'll need an antenna adapter as well, about 10.00CAN. As far as the kits go try this one.
http://www.metraonline.com/product.aspx?sku=99-4544
Theres a couple more kits with EQ provisions, namely the 99-4545 and 99-4812. Not sure but check them out.
ice8168
Copper - Posts: 52
Posted: September 19, 2005 at 1:47 PM / IP Logged
Thanks for the link.  It dosent say the kit will fir an o4, but it may be worth a try.
jstruckman
Copper - Posts: 465
Posted: September 19, 2005 at 3:32 PM / IP Logged
Silverado's are the same from 03' to 06', that Metra part will work just fine,
Jazzy
ice8168
Copper - Posts: 52
Posted: September 19, 2005 at 4:44 PM / IP Logged
They dont have 03 listed.  Their listing only goes to 02.  Is it still the same?
