98 intrepid es intelliguard door locks
mrcllusb
Copper - Posts: 489
Posted: September 19, 2005 at 2:57 AM / IP Logged
I have a 98 dodge intrepid.On the clifford intelliguard 6000,pin 13 gray/green is the lock output and pin 14 gray/orange is the unlock output.Do it tap into the relays that are in the fuseblock,or since clifford make there door lock system to work with either polarity,and can grab the lock/unlock wires fom anywhere?
"ole blake"
mo12v
Posted: September 19, 2005 at 8:19 AM / IP Logged
I have been known to tap into Factory Relays on Dodge products.............
Sometimes it is easier.  On some, U can even get Driver Priority if it has 3 Relays.  1 for Driver Door, 1 for Unlock other Doors, & 1 for Lock all Doors.
Just make sure you get the correct Negative PIN.
OR:
Power LockWHITE/ D GREEN22 PIN CONNECTOR IN
Power UnlockSINGLE WIRE SYSTEMDRIVER KICK PANEL **
** WHITE/ D GREEN Door Lock Wire Must Receive A 12V (+) Pulse Thru A 2.7K Ohm Resistor To Lock And A 12V (+) Pulse Thru A 620 Ohm Resistor To Unlock.
MO
mrcllusb
Copper - Posts: 489
Posted: September 19, 2005 at 8:48 AM / IP Logged
So even with the way the clifford system is designed for door locks,i still need to add the resisitors inline?
"ole blake"
mo12v
Posted: September 19, 2005 at 9:03 AM / IP Logged
Not if you go to the Relays..............If there is independent removable Relays.  Needs only Negative pulse
OTHERWISE if U do Single Wire hook-up, U will need Resistors
MO
mrcllusb
Copper - Posts: 489
Posted: September 19, 2005 at 9:17 AM / IP Logged
Yeah i think going to the relays will be easier since they are already there..Now do you just spice into the rear of the relays,and what wire do you splice into??
"ole blake"
mo12v
Posted: September 19, 2005 at 9:37 AM / IP Logged
check P M
MO
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
