03 outlander wiring
mightey14
Posted: September 19, 2005 at 9:58 PM / IP Logged
Anyone know where I can get wiring for this vehicle.
thepencil
Gold - Posts: 1,526
Posted: September 22, 2005 at 11:37 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - MITSUBISHI / OUTLANDER / 2003 / Remote Start
12volts blue/white (40A)   +   ignition harness
Starter BLACK / YELLOW   +   ignition harness
Second Starter N/A
Ignition blue/black   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory blue/red   +   ignition harness
Second Accessory blue / YELLOW   +   ignition harness
Keysense RED / blue      ignition harness
Notes: This wire rests at ground with the key out of the ignition cylinder, and goes to an open circuit when the key is inserted.
Power Lock lt. GREEN/ red   -   ETACS ECU, pin 33
Notes: The ETACS ECU is attached to the back of the fuse box.
Power Unlock BROWN / red   -   ETACS ECU, pin 34
Lock Motor blue/black   5wi 28 pin plug above fuses, pin 19
Unlock Motor blue/white   5wi ETACS ECU, pin 22
Parking Lights+ GREEN / WHITE   +   15 pin plug below fuses, pin 2
Parking Lights- N/A
Hazards green   -   ETACS ECU, pin 55
Turn Signal(L) GREEN/ YELLOW   +   15 pin plug below fuses, pin 8
Turn Signal(R) GREEN/ red   +   15 pin plug below fuses, pin 13
Reverse Light RED / green   +   38 pin plug in driver kick, pin 8
Door Trigger brown   -   15 pin plug below fuses, pin 10
Dome Supervision red   -   3 pin plug below fuses, pin 1
Trunk/Hatch Pin common with door trigger wire
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm lt. GREEN/ red   -   ETACS ECU, pin 42
Notes: Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm BROWN / white   -   ETACS ECU, pin 25
Disarm No Unlock see factory alarm disarm
Tachometer WHITE/ green   ac   engine speed detection connector
Notes: The engine speed detection connector is a single pin connector in the fuse/relay box under the hood.
Can also go to one of the ignition coils and use the BLACK/ blue or WHITE/ blue wire.
Can also go to any fuel injector and use the wire that is NOT red.
Wait to start N/A
Brake Wire blue/orange   +   brake pedal switch
Parking Brake yellow   -   parking brake switch
Horn Trigger lt. GREEN/ black   -   ETACS ECU, pin 44
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.03 outlander wiring - Last Post -- posted image.
Tuesday, May 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
