2004 impala oil light reset
Fosgate3
Copper - Posts: 328
Posted: September 25, 2005 at 7:39 AM / IP Logged
I recently installed a Clarion MP850 in my wife's 2004 impala. So far, alll has been well until the last oil change we got. Now the "check engine oil" light will stay on for a while. There is no factory radio as I did the install with the DEI databus/chime module. How do you reset this light w/o the factory radio? Is there a way to bypass that feature altogether?
ziggyb222
Silver - Posts: 593
Posted: September 25, 2005 at 8:15 AM / IP Logged
In the owners manual there is a proceedure to use the radio or another method. If you dont have the owners manual let me know. I have an 03 I can look at...
ice8168
Copper - Posts: 52
Posted: September 25, 2005 at 2:00 PM / IP Logged
Here is the reset procedure stright from GM.Using the Accelerator Pedal
Follow this procedure to reset the GM Oil Life System ™:
  1. Turn the ignition to ON, with the engine off.
  2. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE ENGINE OIL message flashes, the system is reset. However, if it stays on , it did not reset. Repeat the procedure.
Friday, May 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
