relay and radio
redpeppers
Silver - Posts: 483
Posted: September 29, 2005 at 12:21 AM / IP Logged
I have a MSN that is all
Where theres is a wire there's a way.
Rkodis
Copper - Posts: 54
Posted: September 29, 2005 at 12:25 AM / IP Logged
Ok so how do i wire this up?
redpeppers
Silver - Posts: 483
Posted: September 29, 2005 at 12:34 AM / IP Logged
contact me on red_peppers_01@msn.com on msn messanger......
redpeppers
Silver - Posts: 483
Posted: September 29, 2005 at 12:52 AM / IP Logged
85 to ground, 86 from the blue/white wire at aftermarket headunit, 87 from yellow wire at aftermarket car harness (12v+), 30 to remote wire and blue power ant. wire
Rkodis
Copper - Posts: 54
Posted: September 29, 2005 at 1:30 AM / IP Logged
then how will the headunit turn on if i remove the yellow 12v+ (headunit),    from the yellow wire from the oem car harness.
geepherder
Platinum - Posts: 3,668
Posted: September 29, 2005 at 8:31 AM / IP Logged
No, don't disconnect the yellow wire on your new stereo, just tap into it, providing power for your relay.  Tap the yellow wire in the aftermarket harness, not the car harness.  This is the constant.
Paradigm
Silver - Posts: 284
Posted: September 29, 2005 at 10:32 AM / IP Logged
If you only have one amp to power, why would you need the relay to begin with? Unless there are other components you haven't mentioned...
VEHICLE: 2002 GMC Sonoma ZR2
Alpine CDA-7940
AudioControl EQT x2
JL Audio 1000/1
JL Audio 10W6 (originals) x3
Kicker ZR120
Kicker ZR460
Polk GXR-6 x4
Polk GXR-4 x2
Rkodis
Copper - Posts: 54
Posted: September 29, 2005 at 3:12 PM / IP Logged
Ok, so i would tap into the yellow 12v+ from the headunit wire harness, and plug it into the 87 stub.  85 to ground.   86 to headunit blue/white wire.  30 to remote wire from amp.
What about my power antenna wire from the oem wire harness?
Another question: When i plugged the blue/white wire from the headunit into the 86.  Then twisted the power antenna wire + the remote wire from the amp,  into to the 85 it seemed to work.  (this is the same as if i took the remote wire from amp + blue antenna wire from oem car, and twisted them to the blue/white wire from the headunit, it would work basically the same with out the relay) intersting.....
But i still i would like to know how to wire it properly with the relay to power the antenna. Because the way that you guys suggested does not seem to include the blue antenna wire.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
