Antenna location
domiyork
Member - Posts: 38
Posted: September 29, 2005 at 9:21 PM / IP Logged
Hi,
Please any suggestion when placing  the antennas on an alarm system, with the alarm that i work with i try different setting and i am never satisfied , i have tried feeding the wire high up in the dash or over the dash heading closer to the windshield any ideas. Antenna wire is about 2 feet.
thanks,.
jorge
gcorrea
Silver - Posts: 436
Posted: September 29, 2005 at 9:53 PM / IP Logged
thats pretty much it. if you are refering to your range, that depends a lot on interference and the alarms ability to receive it.
gcorrea
domiyork
Member - Posts: 38
Posted: September 29, 2005 at 9:54 PM / IP Logged
 Yeah, i am just trying to get better range.
thepencil
Gold - Posts: 1,526
Posted: September 29, 2005 at 10:23 PM / IP Logged
Lift and Pull the plastic on pilar back. Bring the antenna straight up as far as possible will probably give you the best range. Zip tied the antenna to what ever you can get a hold of. Other than that changing to a different brand would be your other option if you are looking for range.
Be careful whose advice you buy, but be patient with those who supply it.Antenna location -- posted image.
tragik
Copper - Posts: 169
Posted: September 29, 2005 at 10:50 PM / IP Logged
I have had some success with wrapping the antenna really tight around a pencil to give it the shape of a spring, then removing the pencil and leaving my newly formed coil under the dash. Just a thought....
Northstart.....or start it your damn self.
dualsport
Silver - Posts: 983
Posted: September 30, 2005 at 7:10 PM / IP Logged
If you can, try to locate the antenna away from the metal frame, because that tends to ground out the signal. Problem with getting it out in the open is that it becomes more visible, which is probably better avoided; I prefer it more stealthy. The body of the car acts like a Faraday cage which tends to trap the transmission fairly well, so getting it towards the window areas would be more effective.
