alpine sec-100s + power locks
bradm
Member - Posts: 10
Posted: October 01, 2005 at 1:47 PM / IP Logged
i recently discovered that i have aftermarket power door locks in my car. they arent wired up though.
i have an alpine sec-100s alarm, and the instructions are confusing me. there are 3 wires in the door lock harness:
A Drivers Unlock- (lock+)
B Lock-/Unlock+
C All Doors Unlock-/+ (selectable thru setup)
my guesses tell me to wire the drivers side actuator via relays to A and B, and the passenger side actuator via relays to B and C(setup as Unlock-?)
is that correct or am i missing something?
thx.
cntrylvr79
Silver - Posts: 582
Posted: October 02, 2005 at 12:09 AM / IP Logged
You're right thoug hyou could wire both doors using b+c save you a relay and you wouldn't have to hit the unlock button twice to do both doors
Cause I'm So white and nerdy...
First Class Certi-fried installer
bradm
Member - Posts: 10
Posted: October 02, 2005 at 12:15 AM / IP Logged
ya, i kinda want the separate unlocks.
buuuut. im having issues. i wired it all up, went to stick the fuse in and *POP* blew it. cant figure out why its blowing.
heres a diagram of what i did...maybe someone can tell me whats wrong?
alpine sec-100s + power locks -- posted image.
cntrylvr79
Silver - Posts: 582
Posted: October 02, 2005 at 12:24 AM / IP Logged
youre diagram looks ok.  Try running a fused jumper to each actuator around 10 amp fuse should be good.  If the fuse blows then there might be something wrond with the actuator itself
bradm
Member - Posts: 10
Posted: October 02, 2005 at 12:27 AM / IP Logged
i know for a fact the driver side actuator works, i played with it on a spare battery i have. it went in and out like it should.
i dont even have the passenger side one hooked up yet, i was just testing the driver side when i popped the fuse.
cntrylvr79
Silver - Posts: 582
Posted: October 02, 2005 at 12:30 AM / IP Logged
Is it blow the fuse as soon as you put the fuse in or when you try using the transmitter
bradm
Member - Posts: 10
Posted: October 02, 2005 at 12:32 AM / IP Logged
as soon as i put the fuse in.
cntrylvr79
Silver - Posts: 582
Posted: October 02, 2005 at 12:40 AM / IP Logged
Ok so then there's a direct short somewhere try checking your relays then shouldn't have continuity between 30 and 87.  There should be continuity between 30 and 87a.  Check the resistance of the coil  should be around 85 ohms.
bradm
Member - Posts: 10
Posted: October 02, 2005 at 12:48 AM / IP Logged
ok ill check all that tomorrow. i did poke around a bit and tested some things. i checked continuity betweem 87A and 30, and got none...
coil resistance was between 75 and 85 on all 4, but ill check it again in the morning.
the relays are brand new, i hope i didnt fry them.
thanks for the help so far.
cntrylvr79
Silver - Posts: 582
Posted: October 02, 2005 at 12:55 AM / IP Logged
You should have continuity between those.  Worse comes to worse I've got about 50 bosch relays  think I could spare a couple to ya.  It's later I'm tired.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
