98 deville radio
jay3000
Member - Posts: 21
Posted: October 04, 2005 at 6:56 AM / IP Logged
Is there a speical way to install any aftermaket components in the 98 deville base model no bose no amp because recently installed a radio into a 98 deville now the customer tell me after a few hours the car seems to be in sleep mode. What am I 2 do should someway leave the factory radio in somehow.
jstruckman
Copper - Posts: 465
Posted: October 04, 2005 at 9:51 AM / IP Logged
Yes, you need to relocate the factory radio.
Jazzy
bazzgazm
Copper - Posts: 113
Posted: October 04, 2005 at 9:54 AM / IP Logged
i'm not familiar with 98's needing a relocation. JAy if you could explain more so what's going on it'd be alot easier to help you out. I.e. what exactly is going on and after the components, or after the deck did this problem occur?
jay3000
Member - Posts: 21
Posted: October 04, 2005 at 6:11 PM / IP Logged
Well I had the car for a day or two now and it seem like it is not consistent it only does after the car sits over a long period of time. ( a hour or two) But the car conpentents work fine after you start the car. Without starting the the aftermarket alarm won't respond. So I tried ran a sperate 12volt to the alarm and radio and now it respond but the car seems to still be in sleep mode I.e. No dome light cluster resets etc.
jay3000
Member - Posts: 21
Posted: October 06, 2005 at 2:11 PM / IP Logged
Plz help somebody
kgerry
Platinum - Posts: 3,455
Posted: October 06, 2005 at 6:06 PM / IP Logged
what data module did you use when you installed the HU?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
jay3000
Member - Posts: 21
Posted: October 06, 2005 at 8:53 PM / IP Logged
I didn't use a date module.
jay3000
Member - Posts: 21
Posted: October 06, 2005 at 9:00 PM / IP Logged
kgerry
Posted: October 07, 2005 at 1:21 PM / IP Logged
i think you just answered your own question..... use the GMRC-03 for a stable, proper install.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
jay3000
Member - Posts: 21
Posted: October 07, 2005 at 1:24 PM / IP Logged
Thx will do.
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
