2002 Malibu alarm/remote start wiring
Farrell
Posted: October 04, 2005 at 6:41 PM / IP Logged
I need a wiring diagram for a 02' Malibu. Also has anyone had any problems installing remote starters in this car?
mo12v
Posted: October 04, 2005 at 8:22 PM / IP Logged
Try:
Constant 12 voltsREDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightGREEN/ BLACK DR (-) BLUALL OTHERS(AT BCM ABOVE PASS KICK) *
Trunk Pin SwitchORANGE / BLACK (+)AT LIGHT IN TRUNK
Parking LampBROWN (+)AT DIMMER OR REAR BODY HARNESS**
Power LockWHITE (-)IN DRIVERS KICK ***
Power UnlockSINGLE WIRE SYSTEMPANEL
* Diode Isolation Needed, Cathode (Band) Side Of Diode Faces OEM Wires. ** Alt. Parking Light- GREY/BLACK (+) At Switch Or 16p GREY Conn At BCM *** White Door Lock Wire Must Receive A Ground (-) Pulse Thru A 1.5k Ohm Resistor To UnLock And A Solid Ground (-) Pulse To Lock.
Single Wire Resistor Door Locks
Accessories
Window UpD\ D BLUE P\ LT BLUE D\ DK GREEN P\ LT GREEN @ MAIN SWITCH
Window DownF/ GREY F/ TAN R/ PURPLE R/ PURPLE
Ign Key WarnL GREEN (-)STEERING COLUMN HARNESS OR BCM
Trunk ReleaseBLACK/ WHITE (-)AT SWITCH OR BCM
OEM HornBLACK (-)STEERING COLUMN HARNESS OR BCM
HeadlightsD BLUE (-)AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmLT GREEN (-)AT BCM OR DRIVES KICK PANEL
Reversal Rest At Ground Power Window Circuit
Negative Pulse Trunk Release
Remote Start
Tach SignalPU/WHT OR BLU/WHTAT IGNITION CONTROL MODULE *
Ignition #2DARK GREENIGNITION SWITCH HARNESS
Ignition #3ORANGEIGNITION SWITCH HARNESS (HVAC)
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightLT BLUE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightL GREEN (+)AT STEERING COLUMN
Rear Window DefrostN/ATIMER BUILT INTO SWITCH
* Ignition Control Module Is Located On Top Of Engine. * Alt Tach Wire- WHITE At PCM Located Below Driver Dash Near Column
GM PassLock II
Note : The Engine Will Not Turn Over Until The PassLock Is Connected Ignition #3 MUST Drop Out During Start For Remote Start
MO
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
