amp wiring problems
bginamercedes1
Member - Posts: 40
Posted: October 05, 2005 at 12:40 AM / IP Logged
i have a Phoenix Gold Octane-R 8.0:4 R8.0:4 amp (200watts rms) and when i plug in the audio input i get a engin hiz on the bottom audio ports.... i was wondering if i just wire up all 4 speackers to the top port ( the frount set) will all the power be transferd and then i can run all 4 speakers clean.????? or will this just kinda kill the amp?????
dwarren
Posted: October 05, 2005 at 1:13 AM / IP Logged
You will more than likely run into a problem doing this. My guess is it will present the incorrect load and you will have bigger issues.
Some more info might help here. Are you using an aftermarket deck? Hve you tried switching the rca's and see if it is indeed the amp and not the rca's?
fingaz22
Silver - Posts: 410
Posted: October 05, 2005 at 9:40 AM / IP Logged
this happened to a clarion drx i had . it was a bad ground on the main board of the radio. or it could just a bad external ground.like dwarren said switch out the rca's first and go from there. lol
JUST ONE MORE AMP!!!
hu,alpine cva 1005/dva 5205
sound processor,symmetry(first one).
sub amp,power 1000 the terminator.(1992).
subs,spl comp dual 1 ohms.
punch 150hd on a 10" ev.
alotofhighs
bginamercedes1
Member - Posts: 40
Posted: October 05, 2005 at 7:21 PM / IP Logged
i have focal speakers and a alpine deck and i think it could be the rca's..... ill try it out in 1 hour
bginamercedes1
Member - Posts: 40
Posted: October 05, 2005 at 11:09 PM / IP Logged
ok i tryed it all out and did some rewiring and i fixed it.... i just got the magic touch.. thanks to every one who posted.
