2005 envoy wire location
MikeHusain
Copper - Posts: 139
Posted: October 11, 2005 at 1:10 PM / IP Logged
I am looking for the parking light wire and the +dome light indication that will go into the 455G interface which will then convert it into a - input going to my alarm.  The diagrams that I have say under rear seat at fuse box.  How can I access these wires?  Fuse box is giving me a hard time to remove and not sure if I want to remove it.. It has the cpu ribbon cable connected to it.  Also I notice that when I arm the vehicle, the security light flashes for about 20 seconds.  Is this normal? The parking light output and domelight is the only thing I have left.  The 455G activates the parking lights only when arming and disarming, not when alarm is set of by impact thats why I need the parking light wire.   Any input will help.  Thanks.....
kgerry
Platinum - Posts: 3,455
Posted: October 11, 2005 at 1:33 PM / IP Logged
parking light is brown in the larger loom of wires crossing under the steering column... domelight, grab at the light in the headliner on the drivers side... takes 5 minutes....run it down with your antenna cable....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Chris Luongo
Platinum - Posts: 3,746
Posted: October 16, 2005 at 1:19 PM / IP Logged
Below the ignition wiring, there is another harness that runs left to right.
Parking lights negative is gray/black, tach is thin white, brake is thick white-------there are several wires of each color; test carefully to verify.
As kgerry said, it is easy enough to just grab door trigger at the light above the driver's head. If you look closely, there is a place to insert a screwdriver and pop the light out.......pull the weatherstripping away from the door opening, and it will be easy to run your wire.
NowYaKnow
Gold - Posts: 1,217
Posted: October 16, 2005 at 4:52 PM / IP Logged
I will just mirror what they say don't waste your time with the rear fusebox. Oh and by the way Chris mentioned the brake as being a thick white. I know he knows this, but the thick white in that harness is your ignition 2 wire, the brake is just a medium sized wire, and the tach is one of the many smaller white wires. Here I thought I was the only one stubborn enough to test all those white wires! Good luck,
Mike
