Viper 791xv Starting problem
maxspeeds
Member - Posts: 21
Posted: October 14, 2005 at 10:04 PM / IP Logged
I have just finished an install of a brand new viper 791xv.  Everything worked fine the first day.  Remote start worked, and key start worked.  The next day, The car won't start with the key.  It also won't remote start.  So, I unplug the ribbon harness to the satellite pack, (everything else is hooked up to the viper brain)and the car starts right up with the key.  Later on in the day, i plug the ribbon back into the satellite pack and everything works fine again.  The car starts with the key and by remote.
Does anyone have any ideas what is going on?
mrcllusb
Copper - Posts: 489
Posted: October 14, 2005 at 10:06 PM / IP Logged
Could of just been something loose.Make sure all your connections including the ribbon connection and see if it acts up again..
"ole blake"
maxspeeds
Member - Posts: 21
I forgot to mention all wire connections have been soldered and heat shrinked.  Viper 791xv Starting problem -- posted image.
mrcllusb
Copper - Posts: 489
Posted: October 14, 2005 at 10:08 PM / IP Logged
Could the ribbon have just not been in all the way..
"ole blake"
maxspeeds
Member - Posts: 21
Thanks for the quick reply.  I was wondering if it could be the satellite relay pack or viper brain malfunctioning?  Has anyone heard of this before?  Could it be possible that the starter kill relay is not reliably working?
maxspeeds
Member - Posts: 21
Posted: October 14, 2005 at 10:11 PM / IP Logged
Well, actually when the ribbon harness is disconnected from the satellite relay pack, the car starts up normally with the car key.  But, when i connect it back into the satellite relay pack, sometimes the car does not want to start at all (with the car key or by remote)
maxspeeds
Member - Posts: 21
Posted: October 15, 2005 at 1:20 AM / IP Logged
When the car does not want to start, the starter does not even click over.  Its like the starter's power is interrupted.  Is it possible that the starter kill could be thinking it is in armed position?
mrcllusb
Copper - Posts: 489
Posted: October 15, 2005 at 6:21 AM / IP Logged
Could be,just double check that ur connections are correct.If so then try another brain..
"ole blake"
maxspeeds
Member - Posts: 21
Posted: October 15, 2005 at 11:53 PM / IP Logged
bump to see if anyone else has this problem.  I really hope it is not the brain.  I just bought the unit and installed it myself.  anyone know if i can just send it back to dei?
maxspeeds
Member - Posts: 21
Posted: October 17, 2005 at 2:11 AM / IP Logged
bump this has really got me stumped
