sho-me lightbar
suzuki
Posted: October 15, 2005 at 2:57 AM / IP Logged
I just received a SHO-ME LED slim light kit  model  no. 11.8600p for my 2004 Suzuki Grand Vitara.  A wiring diagram came with it but it dosen't specify where to tap into the 12volt pwr source.
I'm wondering if I should run a wire from the battery terminal and through the firewall or from the fuse box.
If from the fuse box is correct, which terminal can I use and how would I run it without ruining anything?sho-me lightbar -- posted image.
Suzuki
fingaz22
Silver - Posts: 410
Posted: October 15, 2005 at 12:23 PM / IP Logged
depends on the amparage it is rated at. if it is higher than 25-30amps i would go to the battery with an inline fuse at most 18" away from battery. fuse it for its amp rating
JUST ONE MORE AMP!!!
hu,alpine cva 1005/dva 5205
sound processor,symmetry(first one).
sub amp,power 1000 the terminator.(1992).
subs,spl comp dual 1 ohms.
punch 150hd on a 10" ev.
alotofhighs
