98 ford windstar remote start
edith
Member - Posts: 19
Posted: October 25, 2005 at 5:39 PM / IP Logged
hi can you tell me if w/o meen whitout98 ford windstar remote start - Page 2 -- posted image.sorry for that ?i speak french tank's edith
mo12v
Posted: October 25, 2005 at 5:41 PM / IP Logged
Depends on use:
Usually w / o does mean With Out..........
MO
edith
Member - Posts: 19
Posted: October 25, 2005 at 5:50 PM / IP Logged
mo12v wrote:
Depends on use:
Starter      RED / Blue or WHITE/ Pink      WHITE/ Pink w/o Alarm in Ignition Switch Harness
ok my husband have a remote starter with alarm is the RED / blue or the WHITE/ pink for him ? tank's edith
mo12v
Posted: October 25, 2005 at 6:18 PM / IP Logged
StarterWHITE/ PINKIGNITION SWITCH HARNESS
METER all of your wires also
MO
stang351w
Silver - Posts: 350
Posted: October 25, 2005 at 6:20 PM / IP Logged
hello, i have done a few of those vans for remote starts and i have found on some that where they suggest (coil, pcm, etc) sometimes doesn't give off a strong enough signal, i've always gone to the injector (there should be one commen colour to each and one odd, take the odd colour) and put the PURPLE / white wire to that...then somewhere in the manual it should have adjusting the tach, or tach settings,  just because the other remote start was programed for your vehicle doesn't mean that every other starter will be. that's a setting inside the unit itself. all remote starters have a tach setting and a way of setting or adjusting it (if not, in my opinion, throw it away)
Tri County KustomZ
certified installer
